converting non hardtop roadster to one
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Basically adding T nuts for mounting the top to the deck lid. You just need good measurements.
You need 4 T nuts and bolts. The two on the sides use bolts that thread into the T nuts. The two bolts in the rear slide into the channel in the top itself and they go through a T bushing. Those studs use a nut on them to hold the top down on the deck lid.
Mid-years only use two nuts (plus the corresponding jam nuts and top bolt), one in each side of the deck lid. The side tabs on the hardtop get bolted to the sides deck lid, by the top of the lock pillars.
The top of the deck lid gets two holes, that stainless steel ferrules go in. The rear bow of the hardtop gets secured to the deck lid, by two carriage type bolts that go through the ferrules and get nuts and washers on them, under the deck lid.
Below are the side nuts, the side bolts, the deck lid ferrules and the carriage bolts.
[QUOTE=gbvette62;1592275589]Mid-years only use two nuts
You removed the rest of my explanation of the parts.
Vetterway (05-25-2016)
[QUOTE=Geralds57;1592276048]
I didn't remove anything. Originally that was all you posted, and that's what came up as a quote, when I clicked on the "Reply" button.
You edited your post at 4:41, apparently between when I quoted your original posted, and finished typing my post and adding the pictures.
Sorry.
Sorry.
1955 copper (05-24-2016)
Location: going faster miles an hour...with the radio on in browns mills new jersey
When I briefly re-installed the hardtop some 25+ years later, I found no reason to drill any additional holes in the deck lid.
If you look closely at a lot of Mid-Years, you'll see quite a few cars with holes in the sides of the deck lid but none in the top.
It was quite common "back in the day" when "correctness" wasn't paramount.
[QUOTE=gbvette62;1592282533]
Sorry.
Ok, now I understand. No apology needed.
Sorry.
2015 C2 of Year Finalist
I'm in the process of doing just that and there are some things that have been left out here. If you don't have a hardtop buying one or refurb on one is expensive. So we'll assume you have one. The new one won't fit well and will rattle like crazy. The back bolts are close to manditory. You'll probably have to mess with the weather stripping to get things to seal properly. The windows / doors are set for your convertible top and need to be readjusted to meet the hardtop. And there is probably something else I haven't discovered yet. It's not just throw it on.
I didn't put nuts on the rear screws as its too close to get my hands in there around the folding top to fit them, but it would seal better if I had. I don't know, but maybe the folding top should be removed to install the hardtop.
When I bought my '66 that's the way the (not original to the car) hardtop was mounted.
I used my hard top [finally] last fall with just the side bolts - it seemed to be attached quite solid enough to me.
