[C2] having charging problems
Old May 28, 2016 | 09:38 AM
White 64's Avatar
White 64
Default having charging problems
The condenser on the voltage regulator is for radio interference, is that correct ?
Old May 28, 2016 | 09:46 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Indeed -- that is their only purpose....if original, they have long since died (gone open) and are inoperative but not affecting your charging issue...
Check the voltage across the battery at fast idle - it should be 13.8-14.2 or thereabouts; if lower (12.8 say) your alternator is not working; if higher by much the regulator is letting things 'run away'.
I'm not a big advocate of parts swapping without a diagnosis but its almost worth it to have one of those Wells VR-715 solid state regulators laying around just to swap in and see if your old V/R has croaked - they cost all of $24 at any parts store.
Old May 28, 2016 | 10:31 AM
White 64's Avatar
White 64
Alternator has ben checked by Oreilly and a local auto electrical shop, replaced the vr-715 with another vr-715, cleaned the firewall connectors, checked the continuity of the field and armature wires, good grounds at the VR. Battery gauge shows discharge and more discharge with headlights on, rpm makes no difference. Car has recent engine harness. What should I try next? Everything was fine until I left the interior lights on and drained the battery. Recharged the battery and checked it with a load meter, holds a good load and starts the car but no charge. At my wits end, any ideas? Duane
Old May 28, 2016 | 10:42 AM
Frankie the Fink
Army
You might want to take a look at this very recent thread:
https://www.corvetteforum.com/forums...or-issues.html
Old May 28, 2016 | 01:48 PM
plaidside's Avatar
plaidside
I have an article that I wrote describing the system and how to diagnosis it.
Send me your email address.
Joe
Old May 30, 2016 | 02:08 PM
White 64's Avatar
White 64
Default e-mail
Joe
Please send to bakerduane12@yahoo.com. thanks Duane
Old May 30, 2016 | 03:34 PM
plaidside's Avatar
plaidside
Article sent.
Joe
To having charging problems
