Sidepipe Cover Replacement
A number of years ago there was a small accident due to a stuck throttle. Car sideswiped into a brick mailbox destroying the driver side pipe. Since then I have had the exhaust portion replaced, but the cover was bent (impacted the center) and ripped out of the fiberglass.
I finally have got to replacing the cover and had a question as to the best way to do this. I was going to attempt some minor fiberglass repair or simply fill with resin, but I'm wondering if I even need to do that. Below you can see the passenger side that was installed almost 10 years ago using large rivets. I'm wondering if I could take it to a shop and have them simply rivet the cover on the driver side similar to the passenger side. Thoughts?
Received 2,127 Likes
Where is the trim retaining strip? You should do it right with fiberglass repair. Dennis
Yes - they kind of took a short cut with that pop rivet. You need to install the retainer bar to secure the molding that goes over the top of the cover. As an option to repairing the fiberglass at this time you might be able to use some of those flat steel nut plates. Not sure what the correct term is for them but they are the little rectangular, slightly curved, spring steel pieces with a screw hole in the center.
It's a piece of strip steel roughly 1 inch wide from memory with a rolled bead top and bottom. The upper rocker molding flange secures behind it to hold it in place. When installing the screws that secure the metal strip and the cover, you have to leave them a little loose so the rocker molding will be able to slide down over it. It's a bit tricky as it can scratch the paint above on the fender areas. Some have removed a wheel and slid them on from the end. Just about any Corvette parts house will have them and except for shipping they should be pretty inexpensive.
I may be incorrect on this but I believe that retainer strip is used for both the standard under-car exhaust rocker moldings and the side pipe exhaust rocker moldings. So, it's probably not specific to the side pipe cars. Not sure of this - both C2 Corvettes I've owned had side pipes.
You are correct, the same retainer strip is used for both side exhaust trim and the standard rocker panel moldings.
-Michael
