Reversed Steering!?
Old May 31, 2016 | 11:36 PM
bk2w's Avatar
bk2w
Default Reversed Steering!?
Folks,
I have a '58 that had been (poorly) modified to install a power steering box. It was using rag joints as a u-joint, and would occasionally and with no warning shred the rag joint leaving me with no steering control. Hardly acceptable. On top, they had butchered the column, cut a notch out of the frame and welded the pump bracket onto the motor mount obstructing one of the mount bolts.
So, I acquired a steering column, purchased a rebuild kit from Zip Products, and set to work rebuilding the acquired column, ripping out the bodged in box, and putting things to right. Copious reference was made to the ST-12 and Joe Calcagno's rebuild notes. And everything came together well and looked good.
Until I got to the adjusting process, where I finally get things lined up and realize that the steering box is working in reverse! Turning the steering wheel to the right turned the wheels to the left. The only thing I'm able to figure is that somehow the worm gear in incorrect and spirals the wrong way.
So, before I rip everything apart again, is there anything else that could cause the steering to be reversed? Do we know of these wrong-spiral worm gears in the market?
-Brian
Old May 31, 2016 | 11:42 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Old May 31, 2016 | 11:43 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Originally Posted by bk2w
Folks,
-Brian
Would this occur if the two hoses were in the reversed position?
Don
Old Jun 1, 2016 | 12:01 AM
Frankie the Fink
Army
Don
It is my impression he returned the car to factory manual steering..
Old Jun 1, 2016 | 12:03 AM
bk2w's Avatar
bk2w
Don
Ah, I failed to mention that the newly installed box is a non-power unit as originally equipped. So, no hoses involved at all. Casting number on the box is is 5666151.
This picture is a view from the left front wheel well towards the center of the car.
-Brian
Old Jun 1, 2016 | 05:34 AM
emccomas's Avatar
emccomas
We need to see pictures of the steering linkage setup that you have. Post pictures of the other side of the steering box, including the pitman arm and connection to the steering linkage.
Old Jun 1, 2016 | 08:15 AM
MikeM's Avatar
MikeM
There may be something installed 180* off there.
Old Jun 1, 2016 | 10:33 AM
bk2w's Avatar
bk2w
View of the pitman arm, drag link and third arm, taken looking towards the front of the car.
Old Jun 1, 2016 | 10:37 AM
bk2w's Avatar
bk2w
And the back of the left front wheel, looking forward.
Old Jun 1, 2016 | 10:42 AM
Plasticman's Avatar
Plasticman
Please confirm that your tie rods are located in back of the "A" arms (where they "should" be).
And let us have a picture of your 3rd arm with the center tie rod ends.
Just a guess here, but bet that the added on power steering gear forced the PO to reverse the spindles side to side, which put the tie rods forward of the "A" arms, and reversed the direction of motion..
Plasticman
Old Jun 1, 2016 | 11:15 AM
bk2w's Avatar
bk2w
Plasticman
Eureka! The tie rods currently connect to the steering arms in front of the A-arms. I'll have to switch things around to fix that.
Is there anything different between L and R steering arms, knuckles or control arms? Any way of telling which side the parts should be installed on?
-Brian
Old Jun 1, 2016 | 11:21 AM
emccomas's Avatar
emccomas
Your pitman arm (the arm coming off of the steering box and connecting to the steering linkage doesn't look right.
There should be a number cast into the pitman arm. Can you tell us what it is?
Old Jun 1, 2016 | 11:28 AM
bk2w's Avatar
bk2w
The pitman arm's casting number if 3714674, which I believe is correct for a '58. The PO had severely modified the original arm, so I purchased this unit as a replacement from rarecorvettes.com.
What aspect doesn't look correct?
-Brian
Old Jun 1, 2016 | 11:33 AM
emccomas's Avatar
emccomas
-Brian
Maybe it just isn't on the steering box in the correct position. It seems to be way toward the rear of the car.
It may need some adjustment once you resolve the spindle issues. Good luck with it.
Old Jun 1, 2016 | 11:43 AM
Plasticman's Avatar
Plasticman
-Brian
Brian,
I think that the tie rod arms are bolted to the spindles, and you would need to unbolt them, and swap them side to side, and aim them towards the rear.
Here is a link to a terrific front end rebuild thread by Tom Parsons (DZAUTO here on the forum), but he does not get into that aspect in this thread.
http://www.chevytalk.org/fusionbb/sh...hp?tid/218134/
Plasticman
Old Jun 1, 2016 | 12:04 PM
bk2w's Avatar
bk2w
Brian,
Plasticman
Plasticman,
I've seen Tom's fabulous write up, and I do plan on eventually rebuilding the whole front end much as he lays out. I was hoping to postpone that for now, though, since I'd really like to get the car back on the road and enjoy it for a few months before tearing it apart again. It's already been on cinderblocks for 2+ years while life happened.
http://www.superchevy.com/how-to/pro...ebuild-part-1/ is another rebuild thread that does show a nice picture (#5) of the tie rods and the steering arms pointing to the rear. My setup does not match that, so I'll see about swapping the arms later this week.
Thanks!
-Brian
Old Jun 1, 2016 | 12:17 PM
bk2w's Avatar
bk2w
That photo has the steering turned to one side, with the drag link pulled far back. That might be skewing the perspective.
One issue on placement I haven't found a solution for is that the PO notched the frame to install the power steering box, and welded in some angle-iron to form a mounting bracket. I've cut out the angle-riron, but the notch is right where the manual steering box bolts on. I have the correct iron spacer installed between the frame and the box, and added spacers (grade 8 nuts and washers) to put the box close to where I think it should be, but I don't have any hard measurements to confirm that I've got the right distance. I think the only issue I might have is that box is rotated a bit along the axis of the column, which shouldn't affect the steering significantly. Eventually, I'll be getting help to fix the frame, but that's a bigger task than I can tackle right now.
It's a good thing I enjoy pulling parts off this car and fixing them up, since so many of them seem to need it.
-Brian
To Reversed Steering!?
Old Jun 1, 2016 | 12:28 PM
Plasticman's Avatar
Plasticman
Plasticman,
Thanks!
-Brian
Brian,
Good article and thanks. Note that on the article's #18, they show a Fatman dropped spindle support, and stated the following:
"18. Drop spindles, or spindle uprights, like these from Fatman Fabrications (top) effectively raise the mounting point of the wheel up into the wheelwell, rather than decreasing the suspension travel with lowering springs or coilovers like on a late-model car. It is the only way to effectively lower the ride height on a C1."
This is not true, since 53/54 Chevy passenger car spindle supports will bolt right in, and drop the front end down 3/4" (Tom Parsons put me on to that, and I did it a few years ago). I looked at the Fatman supports, but their drop is about 2"!
Good luck,
Plasticman
Old Jun 1, 2016 | 05:43 PM
steampunk c1's Avatar
steampunk c1
Can you post a pic of the 3rd arm it must be modified to place the tie rods in front of the axle.
Old Jun 1, 2016 | 07:14 PM
bk2w's Avatar
bk2w
The third arm looks exactly like photo #5 from the superchevy.com article. The modification is on the steering arms at the wheels. Original design had the arm trailing the steering knuckle with the tie rod connection behind the axle. My car had them swapped so that the steering arms are leading the steering knuckles, putting the outboard tie rod connection ahead of the axle.
-Brian
