gas tank
gas tank
hello everyone just realized I have a pin hole in side of my gas tank from previous owner screwing in a leather panel on back of seat.i will be pulling tank out and just asking if anyone had any problems pulling the rubber neck where you fill up.also would like to know if anyone has ever used permatex gas tank repair.thanks
Received 2,127 Likes
Personally, I would not put a bandaide on it. Remove it and have it professionally repaired. Dennis
You could try the Permatex 'patch' but I agree .. a proper fix is best.
I tend towards 'overkill' on safety items, gas tanks and brakes being two of those areas...
Received 1,843 Likes
I have known some that have shot a bigger diameter screw in the hole to seal it for a permanent repair.
If the tank is in otherwise good condition and you can reach this spot, one idea would be to take a small SS sheet metal screw and screw it in to the hole to stop the leak. If it's visible (and it bothers you) you could even file the screw head nearly flush and ad a dab of JB Weld.
Sure beats removing the tank and having to get it welded some place. Pilot Dan
Replaced my gas tank a few years back. Wasn't a real tough job, having side pipes instead of the standard exhaust made life a lot easier. If you think your tank can be salvaged, don't screw around. Take it out and have it done right. Safety is paramount. A C2 on fire is not good theatre.
Received 6,943 Likes
2015 C2 of Year Finalist
New correct tanks are relatively cheap. They look and fit just like orginal. I wouldn't even think about repairing one if its old. Chance are that pin hole isn't the only one that will show up. So buy a new one and have peice of mind for the next 50 years
Jack
Received 1,857 Likes
Received 1,534 Likes
I have used various adhesive products to try to repair pin holes. Found none permanent. After a few years, they started seeping.
I vote for getting it welded if the tank is sound. Second is the screw with a gasket under the head or a blind rivet with a gasket under the head. These are permanent repairs.
Just to be clear, I would only recommend the screw repair as a quick fix to an otherwise perfect rust free tank that got a pin hole from the OUTSIDE IN not the other way around (to fix rust). If it comes down to removing the tank, just replace it. That's a no brainer, they are cheap, and not worth welding an old one which likely has some fine rust after 50 years.
The screws used to secure the filler necks to the tank have a tapping ring spotwelded inside the tank that have adequate threads for the screws. Since it has to come out anyway, I suggest you replace the tank just like all the others have recommended.
Mike T - Prescott AZ
It's all what you can afford.
Best: Buy a new tank if you have the funds. $$$$
Second best: inspect the tank inside and out for rust and corrosion. If none or surface rust with no pitting, have it welded. Clean up the surface rust and coat it. Unless you are going for the GOLD. $$
Third best: inspect the tank inside and out for rust and corrosion. If none or surface rust with no pitting, sheet metal screw with fuel resistant washer for a quick, cheap, but not permanent repair. $
Fourth: Hole in rusty tank, pitted and on the edge of additional leaks other than the BUBBA puncture - Bite the bullet, sell the kid's candy and video games and pawn the wife's diamond, buy a new tank. $!$! They will forgive you in 20 or 30 years, maybe.
Good luck.
I don't have an answer to the rubber neck question, last time I dealt with one was not on a gas tank, but a red head. Anyone give him pointers on the RUBBER NECK??
Is this a C1 or C2???
Good luck.
Good luck.
Good luck.
2018 C1 of Year Finalist
Even as a small boy I thought to myself. This woman needs to get out of her rocker and help the poor old man out!
Replace the tank
Just saying that's my experience .
In this case, the SCREW would plug the leak and the JB weld would lock it in place from the outside. Not suggesting to use it as a sealer by itself which sounds like what you did.
rtruman (06-14-2016)
Replace the tank - no-brainer. They're cheap.
