[C1] pilot bearing part number?
I can find pilot bushings for my 59 BW but all are magnetic. Do any CF members know where to buy brass bushings unmagnetized? Thanks 59 navy
We carry a large inventory of asst'd pilot bushings, the only bearing we carry is for the Pontiacs.
Thanks, Gary in N.Y.
P.S. Also, what is a "BW"?
Federal-Mogul PB656HD is non magnetic. That being said, I can't find a source for one online. However, Rock Auto has the National PB656HD, and National is owned by Federal Mogul, so there is a good chance it is the same bushing.
Pioneer and SKF are magnetic.
I found that there are usually two bushings listed at a dealer under the same company. The standard one is usually magnetic and the HD one is the non-magnetic one. I believe I last used a National HD one.
Bushing
Borg Warner T-10 Side cover 148 B (1960-1963) Main case is T-10 1B (July 59 through Nov 60) Tail is 7 B (60-61) Not correct for 59 but an earlier rebuild using several transmissions. I think I've got it copied down correctly. 59 navy
We just went thru this question a few weeks back...........so info is there if you search.
Larry
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
