Help with transmission date code
Hey all, I have a 64 fuelie convertible and trying to decode the transmission date. The attached pic shows driver side main case with the VIN derivative stamped vertically. This matches the car's VIN, no problem there. Just would like to understand the date of tranny assembly & if it too matches up.
The stamped code lower in the pic, not sure if this a date code or not. There is no stamping at all on the passenger side.
Can anyone help? I have other pics with casting #s, and a bolt tag that matches up with a 64 close ratio Muncie: 3839601
Thanks in advance for any help.
Dave P
Minnesota
Dave P
Minnesota
Dave P
Minnesota
Dave P
Minnesota
P stands for Muncie
10 is October
1 is the first of the month
I am a little confused to see a single "1" for the last digit - would have expected to see "01".
Since this is in a 1964 car, the transmission assembly date must have been in October 1963. What is the VIN and or body assembly date of your car, and how does that October date match up?
P stands for Muncie
10 is October
10 is October
Thanks tuxnharley,
The body assembly date is B14, or Oct 14 '63, car was no. 2805 in the run.
Dave
