[C2] Block Plug sealant?
Block Plug sealant?
I just ordered a new DeWitt's radiator and want to drain the block as i did not use distilled water originally. Going to use Zerex G-05 as was recommended by DeWitts to refill.
can some let me know what type of sealer I need to use on the block plugs when I reinstall them?
Thanks!
Thanks!
Bruski (07-02-2016)
Received 6,944 Likes
2015 C2 of Year Finalist
they are NPT so no sealer is needed. but if you must use the Permatex liquid Teflon. stuff works great
Originally Posted by BD104X
It's plugged with sediment. Poke in there with a screwdriver and get ready for a face full of old coolant.
Thanks.
Antifreeze is orange rusty color........
With them out its the time to flush the block out with your garden hose. Run water though it until clean water comes out.
Perimeter #2 non hardening sealant on the block plugs and just snug the up.
sand blast or wire wheel the plug, etching primer on the threads and anti sieze. better yet, get new plugs.
Received 1,126 Likes
When I bought my 64 I went to drain the block and there were no pipe plugs!
The block was so packed with crud the PO never put them in.
And when I poked the holeds I did get a bath from both sides.
I use new 1/4 brass plugs and teflon tape to make future removale eaiser.
Joe
Joe
I bought my '63 Corvette (250hp-327) from the original owner in the fall of 1969 in the NE U.S.. Very soon I discovered that the heater didn't appear to work. It would blow plenty of air, but it was always very cool. The engine felt warm but never hot. Someone suggested checking the thermostat, so I did, only to discover that ...there was none. I installed a new 180 degree thermostat and bingo, I now have heat. Unfortunately shortly after that I realized why the original owner had removed the thermostat, as the radiator began to leak. Replaced the radiator and I was back in business.
By the spring, I had accumulated a few items to upgrade the power and decided to pull the engine to make the changes and freshen it up, it was burning a bit of oil. When I tore down the engine I discovered that the original owner was a true believer in radiator stop leak, specifically Bar's Leaks, a common solution back then to leaking cooling systems. It had the consistency of thick chocolate syrup. He had however dumped so much Bar's Leaks in the engine that the water jacket of the short block was filled solid with it from the top of the back of the block to the bottom at the front of the block with it.
Clearly the rear two cylinders and most of the next two were receiving little if any cooling from the water in the engine. This also probably explained why the rings were "cooked" and it burned a significant amount of oil, considering the car had less than 30k on it at the time.
I had never seen anything like it before, or since and have never used it in an engine of mine after seeing that. It took most of a day with brushes and a long welding rod to free that stuff from the block, before taking it to a machine shop to have it professionally cleaned.
Good luck... GUSTO
Good luck... GUSTO
Drain plugs
If you haven't put the plugs back in yet, take a wire hanger and poke around in the holes with that---a screwdriver does not bend and can only clean the immediate area around the hole---a wire hanger can reach the front & back of the block. Pull the thermostat and feed water in through there to get all of the loose crap out. When you're finished, go to your local auto parts store and get 2 brass radiator petcocks. Install them with Teflon tape or any sealant of your choice and from that point on you can drain your block with no more headaches---Just open the petcocks.
RON
NPT threads need sealant
The threaded block plugs are NPT standard tapered pipe threads. This thread system is designed to be used with a sealer. Teflon tape, Teflon pipe sealant or old fashion pipe dope will assure a leak free installation. You can get the sealant at Home Depot or local FLAPS.
Grampy
Grampy
Had to remove the starter brace 'cause I couldn't open the petcock enough to get it to drain. Not a big deal but, why make it harder so I replaced them with the standard plugs. Also I think its easier to run a wire through the jackets and they drain better as well (bigger openings).
with purchasing a new set of plugs then, using one of the aforementioned coatings.
Gary
Put the new radiator in this weekend. What a difference. Does not go above 180 while cruising.
When I stop and idle in my driveway the temp does creep up pretty fast but as soon as I go down the road again, it goes right back to where it should. It went from 180 to about 210 in about 3 or 4 minutes of idling after an hour drive.
That should take care of the problem.
I assumed that you have a good working vacuum advance on the distributor. If you don't, or don't know, this could also contribute to the issue.
Larry
