'64 wierd brake problem
Old Jul 6, 2016 | 12:23 PM
dlaw7822's Avatar
dlaw7822
Default '64 wierd brake problem
Just purchased a nice '64 coupe and on the way home my wife informed me that the brake lights were out. So far : cleaned all tail light contacts and installed new 1157's w/ bulb lube. Same with all #90 inside bulbs. Now brake lights and courtesy lights will work until the brake pedal is pressed, then the mentioned lights all go out. A few seconds later the lights will reset ( like a circuit breaker ). The PO installed a 30 amp fuse and I will change it to a 20. I think the turn sig. or brake light sw.could be suspect . This is an a/c car and changing either one of these components would be tough ( for me ).Any one had to deal with this issue in an a/c C2 ? Thanks, DL.
Old Jul 6, 2016 | 01:08 PM
Westlotorn's Avatar
Westlotorn
I can't give you specific help but in one of these Corvettes remember the body is fiberglass so it does not provide a ground. Every light has to have its own ground wire. This is unique to fiberglass cars. Maybe you are losing your ground affecting your lights.
Old Jul 6, 2016 | 02:36 PM
dlaw7822's Avatar
dlaw7822
Thanks, Westlotorn. Apparently, the brake and interior lights share a common ground as they all fail in unison, then re-light. Hopefully someone has experienced a similar problem and will save me a lot of grief. DL.
Old Jul 6, 2016 | 05:08 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
If you don't have the Chassis Service Manual, you should get one. It has the wiring diagram in it, Dennis
Old Jul 7, 2016 | 12:49 AM
buns's Avatar
buns
Could you snap a pic of your fusebox? Fuse should be a 15 amp, not a 20 or a 30. Fuses don't blow then heal themselves.
Appears the previous owner was having issues or he would not/should not have installed a 30 amp fuse.
Old Jul 7, 2016 | 08:11 AM
dlaw7822's Avatar
dlaw7822
Thanks,buns. Some c/b's, unlike fuses will in fact reset, once they cool. I agree the PO tried a bad fix, and potential fire hazard. Only had the car a week and just received a shop manual.( my refrigerator manual has more detail ) More manuals on the way.The fuse panel looks factory and in good shape will get some pics. DL.
Old Jul 7, 2016 | 04:50 PM
rene-paul's Avatar
rene-paul
You mentioned shop manual, you may only have the 1964 Supplement. You need a 1963 Corvette Shop Manual, the 64 supplplement only has the changes for the 64.
Brgds,
Rene
Old Jul 7, 2016 | 08:49 PM
dlaw7822's Avatar
dlaw7822
Brgds,
Rene
Thanks, Rene-Paul. Will do.
To '64 wierd brake problem
