My 67 427/400 has developed a strange backfire problem. I drive the car to a local car show 5 miles from my house on Thursday nights. On a typical night, it sits for about 3 hours before I start it to go home. For the last two Thursdays, it has backfired through the side exhaust when I go to start it for the trip home. The backfire is a big one! I drive the car a lot, and this is the only time that I get the problem. I thought that timing would cause a backfire through the carb, but I checked it anyway. It was set at the spec. My next thought is that some gas is finding it's way into the exhaust while the car is sitting. The carbs seem to be fine and the gaskets are new. Has anyone seen this before?
First thing, before starting the car next time remove the air cleaner and look down into the carb throats to see if there's a bunch of gas on the manifold. If so, something is going on with the carb like a stuck float bowl needle. If not, then it may be an ignition issue. One or more cylinders aren't firing at times. They build up unburnt gas then fire off and..........BOOM!
Does it have to turn over a few times more than usual just before the backfire? If so, (and there's no sign of gas on the manifold) I'd be looking at an ignition issue such as the the coil or loose connections. Also could be a bad plug/plugs or wires. Good luck.
Gary
It possible your center carb is leaking some internally over that three hours. That couples with your timing being right on the edge could cause the backfire.
I was having a similar issue with my 57, it would occasionally backfire on cold start-up, and sometimes after sitting for a few hours. Also I was having an intermittent misfire when cruising. Turned out to be a bad coil. Good luck.
I checked all of my connections and they are good. The engine was rebuilt less than 500 miles ago and it has electronic ignition. I tried to duplicate the conditions, but I could not get it to backfire. It must know when people are looking.
Backfire is caused by unburnt fuel getting past the exhaust valve and igniting in the tailpipe. Also retarded timing could also cause it.
No, that's afterfire. Backfire is when it spits back up the carburetor, usually accompanied by an orange ball of flame if the air cleaner is not installed.
Be careful!
The OP's situation is afterfire, not backfire.
Remove the air cleaner cover after shutdown and check to see if any fuel is dribbling out the the booster venturi nozzles. If so it could just be a float level adjustment, but a leaky needle and seat is also a possibility.
