A/C compressor throwing oil?
It appears that the A/C compressor is losing a bit of oil, but so far not much. So my questions are:
- What is this oil? Is the compressor designed to lose a certain amount?
- How do refill the oil?
- How much oil is contained in the compressor?
- Should I worry about the amount being lost? As I said, it isn't much, but over time will the loss of oil damage the compressor?
- Is the oil being lost whenever the engine is running (i.e. rotating the compressor pulley), or does oil only get lost when the A/C compressor is engaged?
- Is there supposed to be a guard or shield in place to keep the oil from being sprayed on the underside of the hood? Where should this guard or shield be installed?
- Lastly, what do I need to do to fix the leak? Is a full rebuild of the compressor required?
http://www.ecklerscorvette.com/corve...1963-1976.html
That is your biggest issue/concern. The others are minor in comparison.Now for your other questions:
1. There is 11 oz of mineral oil contained within the C2 Corvette AC system. It provides lubrication to the compressor and other AC parts. The AC system should not lose any measurable amount of oil. R12 is also lost along with the oil.
2. You can buy cans of the special AC 525 SUS mineral oil that are under R12 pressure and add them SLOWLY into the compressor suction. You could also buy a special AC tool to do this. Or you could depressure the system, add the oil, and then refill the system with R12 again. The question becomes how much do you add?? You do not want to overfill (or underfill).
3. The compressor holds about 4-6 oz of special mineral oil. The rest of the system holds about 5 oz of oil. Total system oil charge is 11 oz.
4. Yes you should be concerned about the oil loss. It will damage the hood fiberglass and could also damage the compressor (if too much oil is lost).
5. Typically the most oil is lost when the compressor is running, but it could also be lost if the compressor is off..........if the compressor seal is bad enough. However, in this case, you would also quickly lose the R12 refrigerant charge.
6. The factory did not provide a compressor seal shield, but you can buy one from a few Corvette parts suppliers. Ecklers is one. The current shields were designed by a member of our C2 forum. I helped him initially in this work. There are pics of the development in the archives. The guys screen name is Nitromainia. His actual name is Kevin. You can find the pics if you search under his screen name in the C2 Forum.
7. The compressor seal needs to be replaced. You can do this yourself with the right tools and knowledge, however we have recently determined that the current ACDELCO replacement seal is basically junk. Dom Tallarita is a member of this forum and has the skill and correct/alternate parts sources to replace the seal and rebuild the compressor. He is the best in the country for this work. You can try it yourself, contact Dom, or buy a new A6 compressor from ALMA Products in Michigan. The new compressor will look like the old one, but will be metric and have a modern double lip seal on a chromed compressor shaft.
Larry
Larry
As mentioned above, Dom Tallarita is the expert to rebuild your A6. I spoke to him once and he is one great guy and knows his stuff.
How can I tell if my system has been converted from R-12 to R-134A? I can't see any decals or other info (other than the stock Frigidaire decal on the compressor.
Is it feasible to add the correct oil to the system without having to recharge the refrigerant?
First you need to determine if R12 or something else. If the AC suction and discharge fittings are still the R12 Schraeder type, chances are it is still R12. A very good AC shop can analyze the refrigerant and tell the differences. You can also check the pressure versus temperature in the system and perhaps tell the difference.............but you need to keep the temperature CONSTANT in an insulated garage or storage building for about a day or two to let the temperature stabilize so you can get an accurate pressure vs temperature reading.
If R12, you can buy cans of refrigerant and oil mix and SLOWLY (very slowly
) add them to the system. I guess you could do this either running or off, but the add procedure would be different. Let me know if you go this way. Then you can crack open the drain connection on the A6 compressor with the compressor off and see if oil comes out. Oil will only come out if the compressor is overfilled.............if no oil comes out (only refrigerant gas) then the oil level is either low or okay. Dom brought this fact out a few years ago. You could call him for additional details and ask more questions if needed. He has the most knowledge about the compressor internals and what steps are needed to be done. It may even be in the archives under his name, since he explained it all to us awhile back. http://www.ebay.com/itm/INTERDYNAMIC...RXafAl&vxp=mtr This is the oil in a can............price is way too high, I bought all mine for about $2/each many years ago. I guess "supply and demand"
The other way is to completely discharge the system and measure the oil in the compressor. Then add back the correct amount. The Chevrolet Service manual Section 1A has the procedure for this.
Larry
Other compressors have different shields............I know the R-4 compressor had a special one. Not certain about Sanden, Pro6Ten, Denso, etc.
You can also make one with a bit of time and skill. That is how the current A6 shield came to be. After the prototype was build a commercial sheet metal shop took over the job of making the others.
Larry
Larry
You are the expert on the system and I would like to get your opinion on the oil that is compatible with R-12 & R-134? I know it is always best to keep all oils the same but some shops are using the oil that works in both.
Dom
Yes, Ester Oil is compatible with both R12 and R134a refrigerants, and is the choice for folks converting from R12 to R134a. It will mix and should not create any issues in either R12 or R134a systems. I believe that Ester 150 viscosity is the best one to get for our old A6 compressors, but Ester 100 viscosity (thinner oil) will also work just fine. The 150 should provide a bit more protection for the system in the hotter climates where AC is normally used/desired. However a friend in Connecticut (Northeast part of the country) used 100 viscosity last year and it was just fine.
Here is a good writeup on the various oils, etc. But then again you already know this.
http://www.e38.org/pparish/oil.htmI believe a person can buy mineral oil, ester oil, and PAG oil all pressurized under their compatible refrigerants in small cans, just like the picture I posted earlier for R12. But you have to search a bit.
I just don't like adding ester oil to a system that might have another oil already in it..............without first trying to remove the previous oil.......even if they are supposed to be compatible.
Larry
EDIT: Another table about oil types and viscosities for everyones reference. Although this shows Ester 100 for the A6 compressor, other companies/rebuilders etc show Ester 150. http://www.e38.org/pparish/oil-tabl.htm
Larry
Thanks,
Rich
Being that the hood is metal/steel the mineral oil will not harm it or the exterior paint. Now if you switch to R134a and PAG oil..............well
I never had a shield for the A6 compressor on that car and never needed one. But as stated earlier, you could "reverse engineer" one by using the one that is available for right-hand mount, and then make it up in your shop. Best I can do for you. Back then the compressor shield was a product that wasn't needed...........so it wasn't made.
Larry
Larry
Thanks,
Rich
Larry
