1957 windshield washers
Old Aug 9, 2016 | 01:20 PM
John McGraw's Avatar
John McGraw
Default 1957 windshield washers
Can someone give me a explanation of how the washers function on a 57?
I am putting a car back together for a friend, and I believe I have everything for the washers but the red top for the reservoir. I have the foot pump and it makes good pressure and has no holes in the bellows, I have a coordinator cable to run between the motor and the foot pedal, I have all the nozzles and the hoses.
There was a blue top with all the parts in the boxes that came with the car, but from what I have gleaned, only the red top will work with a 57.
Does the air pressure from the foot pump operate some sort of pumping mechanism within the top to force the water out to the nozzles?
Will any other tops work for the 57?
The top I have only has a single hose port on it, and from the AIM, I can see that the 57 top has two hose ports, one for the hose to the foot pump and another that goes to the wiper nozzles. The guy I am building the car for will never show the car, is just going to be a pleasure driver, so I would put an incorrect appearing part on it, as long as it was functional. I just do not know how the system works.
Thanks, John McGraw
Old Aug 9, 2016 | 02:22 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I have nothing for those earlier systems John....have you talked to Jay Maxwell of Capital Restorations out of Gaithersburg, MD ?
Old Aug 10, 2016 | 12:16 PM
John McGraw
I have left a message at their voice mail, but have not received a call back yet.
Anybody here that can describe the operation of the 57 washer system?
Regards, John McGraw
Old Aug 10, 2016 | 02:00 PM
Frankie the Fink
Army
If you can find the patent number John and look it up in the USPTO Patent Image Database it will describe the operation....might take some reading but it's there.
This is the info I got like that on the later washer systems...for C1s...
File Type: pdf
Old Aug 11, 2016 | 02:04 PM
John McGraw
Really? Nobody?
Old Aug 11, 2016 | 06:52 PM
JohnZ's Avatar
JohnZ
John -
Neither of my 57's had the optional washers, but I judged enough of them over the years to understand how they worked.
Without washers, turning the **** CW turned the wipers on slow or fast, and turning it back CCW caused the wipers to park at operating speed ("slow-park" was incorporated about #1400 or so).
With washers, depressing the foot pump did two things - it squirted washer fluid on the windshield, and a bowden cable from the foot pump to the motor activated the motor to clear the fluid from the windshield, and the wipers parked. A second foot pump stroke squirted more fluid and cycled the wipers again. The only pump device in the '57 washer system was the bellows foot pump - there was no diaphragm or pump in the fluid reservoir as there was in the '58-up washer system.
Old Aug 11, 2016 | 11:21 PM
John McGraw
Originally Posted by JohnZ
John -
Thanks Mr Hinkley!
Jay finally called me back tonight and confirmed what I had guessed. The red top for the reservoir is a 57 only part and no other top will work. The top does actually have a diaphragm pump in it that is operated by the bellows of the foot pump. The foot pump never sees water, only air. Now just need to see if the owner wants to pop for the cost of a red top, to make his washers functional.
Old Nov 18, 2019 | 03:16 PM
KrisKringle's Avatar
KrisKringle
Default Foot pump? Red Lid?
Hello all, I realise this is an old thread, but moving on with Blackie, the customer is looking to get the WW back in order. The only things remaining from the original system are the nozzles on the cowl...everything else is missing. I have managed to source most of the parts from Paragon, (I have given up on Eckler's), and well...getting a blue lid unless someone can help me with red one. Still need the foot-pump though.
HELP!
Thanks,
Jonathan in Germany...
Old Nov 18, 2019 | 03:32 PM
emccomas's Avatar
emccomas
HELP!
Thanks,
I think I have a foot pump with the bowden cable from a 1956 Corvette. You are welcome to it for the cost of shipping if it will work for you. It will need to be restored I am not sure if 56 and 57 foot pumps are the same
Old Nov 18, 2019 | 03:33 PM
emccomas's Avatar
emccomas
HELP!
Thanks,
Old Nov 18, 2019 | 04:20 PM
KrisKringle
Cool! I do not know if they are the same either. I will get back to you. Thanks again! Jonathan
To 1957 windshield washers
