Harmonic balancer
Old Aug 19, 2016 | 01:30 PM
Mikey Hawks's Avatar
Mikey Hawks
Default Harmonic balancer
Would someone look and tell me if this balancer is fully seated? It seems to have bottomed out but I want to be sure. Thanks
Old Aug 19, 2016 | 02:12 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
first question: does the damper have a retaining bolt or is it a 'press fit' on the crank?
second question: is this a previously used damper?
looking at the picture, I don't see any shiny area exposed, so if it is a previously used damper then there would be a shiny area projecting past the seal if it is not seated far enough; I don't see one....
the distance from the edge of the front of the timing tab seems about right as there has the be enough of the damper edge exposed to see the mark on the damper in relationship to the graduations on the tab.
if you had to 'drive' the damper on the crank snout, then when it was seated you should have heard/felt a change in the sound of movement when it seated against the timing gear. if you used a bolt to pull it on they you would know when the bolt won't turn beyond its torque spec (not sure what that # is...)
just my thoughts....
Bill
Old Aug 19, 2016 | 02:20 PM
tuxnharley's Avatar
tuxnharley
Bill
Looks good to my Mark 66 optical calibration. I can't imagine it going on any farther past the timing marks/timing tab relationship.
Old Aug 19, 2016 | 04:11 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
You should have heard a noticeable difference in the sound as you tap it on, even against a solid piece of wood. The ringing noise changes to a solid thunk when it seats fully.
Old Aug 19, 2016 | 05:03 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Looks right for the aftermarket type...(they sit out further than the factory ones)
Old Aug 20, 2016 | 08:43 AM
Mikey Hawks
I should have noted, it is new but I removed it because the seal had a slight drip. It's a press fit, no bolt. Sorry but I wasn't really listening for a sound change while re-installing. I was talking to myself for having to take so many parts off a fresh rebuild to fix the seal.
Anyway, it sounds like most all believe it's good so I going with that. Thank you for the feedback.
Old Aug 20, 2016 | 01:04 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
If you concerned enough you can mark the crank snout and pull the dampener to compare depth to your crank mark.
To Harmonic balancer
