[C1] Florida Garage Heat
#61
Received 1,591 Likes
St. Jude Donor '20-'21-'22-'23-'24
Hi Steve... let me know how your dye job works out. My 67 has perfect original interior and black carpets, with the exception of faded black. I had thought about dying the carpets. I hate to pull out the originals just due to fading as they are otherwise perfect (original only once as they say). But a thread here on the forum indicated poor results trying to re-dye. Like to know how you make out.
Jim
Jim
Yes, I plan on posting with before and after pictures when I'm done. I'm pretty much finished, just doing some touch up. Color is darker than original teal but I'm fine with that. If you have black, I wouldn't hesitate. Teal can be many shades but black is black (with due respect to Los Bravos).
Steve
65GTO (09-12-2016)
#62
i never ran a car inside a garage without extensions on my tail pipes or half rear of car outside with door halfway closed while I am under hood. No good to kill me and family! Always park with rear at door.
think I will start with a dehumidifier with a hose running under my garage door to drop out.
jax
jax
If you are overly concerned with gas fumes as Roger stated, then any source of ignition in the garage is a concern.......... I agree that it is a concern and needs to be addressed, but over the years I have run heaters and other open element and spark producing equipment in the garage without issue. But you never know when the gas tank or a rubber fuel line starts to leak.....or you simply do a dumb thing. That is why you really don't want the garage sharing a system with the house or an open flame source nearby......such as a gas hot water tank.
But you don't need an open flame source to start a fire..........an intermittent spark producing source could also do it.
A dehumidifier running always with a split AC system for days when you are in the garage or the heat/humidity is very high is a nice compromise. But even this has some risk.
Larry
#63
I had a vacation home on Macro Island for a number of years. Had a few of my cars there. This was my experience;
If not apparent from the posts you have read, you need to keep the heat, humidity, and depending on location, salt in the air in consideration as an environmental condition you need to mitigate for anything keep there for any period of time. Notice the environmental controls all the posters have in their pictures.
I did not have any environmental controls in my 5 car garage. So.. heed the advice other give... control the environment
My cars and outcomes... Note.. my home was a vacation home.. so the cars many times never got used even when I was there... too busy always repairing the house (think 24 x 7 heat, salt, humidity).
As an aside, my buddy who collects 30's and 40's Harleys, brought a few down to his place in Naples. I warned him in advance 'do not bring them to a non-climate controlled garage'. Did not head my warning... all his spokes, rims and other chrome bright work are showing rust.
So... I think you know what you need to do.
Jim
- House was for all practical purposes, direct on the ocean.
- The combination of sun, humidity, salt air rusted everything not protected
- My 'tarnish proof' door fixtures were all junk within 2 years (rust and and finish coming off)
- Nearly every outdoor light fixture junk within 2 years.
- Metal doors... all started to rust, even galvy ones.
- Even stainless steel rusts
- All this, on a brand new home, that I 1st hand picked out top of line materials thinking about the environmental conditions there.
- Any unprotected metal would get that rust dust coating on it in very short order (think raw unprotected metal parts on a car)
- Two fuel injected cars (Miata and a Porsche). Both never ran again after sitting the garage with minimal use for a couple years. Turn over, never start. Troubleshooted until I was blue in the face.
- 1942 Chev PU; Generally OK except; Any raw metal parts getting surface rust / dust / oxidation. Brakes and clutch disk seizing to their respective surfaces (both would break free with help of people pushing the car), Mold and mildew accumulation as would be expected.
- 39 LaSalle; Pretty much same as above, but with a cloth interior, mold an even bigger problem.
- Fuel; Due to heat, turns to varnish / crap real fast in the tanks and carb bowls. The heat on the fuel in the injection systems is what I think did in the FI cars.
Jim
#64
Not sure if an electric hot water heater will ignite any possible gas fumes. If so, I don't think they would have put in every garage in my area the hot water heater in garage.
jax
jax
#65
Hot water
An electric hot water heater will ignite it's coils inside the water tank eliminating any open hot coils exposed to gas fumes as they are also sealed in the tank so water doesn't leak out. any possible gas fumes shouldn't be able to ignite. If they did, I don't think they would have put in every garage in my area the hot water heater in garage. All over south Florida houses I looked at too before buying mine.
Gas hot water heaters have a pilot, that could go boom in garage from fumes.
jax[/QUOTE]
jax[/QUOTE]
#66
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
jax
jax
Not really.
A pilot light will burn off any fumes when they are way too dilute to explode.
Do you worry about the spark created by a light switch blowing up the garage? Or any electric motor(air compressor, electric drill, washing machine, vacuum cleaner, etc)?
#67
I had a boss years ago whose forearms were horribly burned. He had an open fuel container in the garage when his water heater pilot light ignited the fumes and he got injured tossing the container outside. Scarred for life.
#68
My main concern about having AC ducts running into the house is that they can carry fire or gas fumes into the house that will make crispy critters out of your family in case of a fuel line leak.
Ps, Gas water heaters in MA. are required to be at least 18" above the floor, as gas fumes tend to stay low to the ground. However, gas unit heaters must be at least 6' high.
(I guess that the gasoline knows enough to stay away from the water heater. (;-) )
#69
Received 2,146 Likes
Electric water heaters I'm familiar with have one or two thermostats mounted behind access panels on the tank but not inside the tank. These thermostats typically switch 240 volts at 30 amps with a snap-action set of contacts that certainly generate a spark. Then again so to do the contacts on the pressure switch of an air compressor, or the motors of all kinds of tools used in a garage.
I think the legitimate worry is a gas/propane water heater or space heater using a unsealed combustion chamber. These most certainly can ignite gasoline and lacquer thinner/other petroleum distillate fumes and therefore ought not be used in a garage.
Most codes require a 2 hour fire separation between a garage & living space, double 5/8 sheetrock on both sides of the wall. Sharing supply & return air between a living space and a garage must be a code violation, I'd never do anything like that...
Dan
Roger Walling (09-19-2016)
#70
Not sharing exhaust, but they are adding an a/c duct. Gonna add some type of vent and dehumidifier. Never got down to it as I told them we will do it next trip down in November. They are the largest and oldest A/C, heating and plumbing in Palm beach county. Called Lyndstrom.
thanks
Jax
Dan[/QUOTE]
thanks
Jax
Dan[/QUOTE]
#72
I installed a Mitsubishi Mr. Slim AC / Heat pump combo unit for the garage. Works great, wasnt too expensive and is completely independant of the house systems.
#74
I didn't think the Jags were that tight and leak free..........where the pressure could build up inside to blow the window. Wondering if something else was at fault.
I ALWAYS store my cars with the windows down and a cover on them. It keeps some ventilation going thru to prevent mold/mildew. I tired it the other way as well (car closed up), but did not like the result. The moisture/humidity eventually goes everywhere.
Larry
Larry
i am going down next week an having my garage cooled and de humidified by Lindstrom A/C service. Either have it added to my unit or a ductless unit.
Last month I pulled Jaguar out and the floor paint came off on my tires.
It was painted in April!
Jax
#75
2021 C2 of the Year Finalist - Unmodified
2017 C3 of Year Finalist
St. Jude Donor '13
That's the ticket and if there's concerns regarding garage fumes getting into the house when the a/c is off, fit a backdraft damper as well. When the a/c is off the backdraft damper closes
#76
Jax
