ZZ4 crate engine issues
original #5 exhaust lifter
When the pushrod first left, I replaced all the roller lifters and all the pushrods. The pushrod that left was not bent - I could probably have reused it, but didn't. I matched the new pushrods to the old ones and they were the same length - same with the lifters. I did not replace the rockers. What I did find interesting is that when I pulled the original lifters, two of them had broken keepers. I found one keeper lying in the valley
Just want to help with this and not flame you for your hard work at this. But without being there to witness the method it is very difficult to say that is accurate or acceptable. It's mainly because no one else does it like that. Though there are plenty of ways to verify the lifter is on the base circle I have never known it to be done like that.
My shop manual for 1974 says to find TDC on #1 cylinders while both those valves are closed and therefore on "base circle". Now you need to be sure #1cyl vlvs are closed because #6 cylinders is also at TDC when the timing tab mark says 0. Next the manual states exh #3, exh #4, exh #8, intk #2, intk#5, intk #7 are all on base circle at this point and can be adjusted. To adj the rest of the vlvs you just have to rotate the motor 1 full turn back to reading 0 degrees on the timing tab which now puts #6 cylinders TDC but w/vlvs shut (on base circle).
Myself I like just to work the cylinders as pairs as I know at TDC and every 90 degrees of crank rotation there are 2 cylinders at TDC with only 1 cylinder having the valves closed and lifters on the base circle. I guess I've just gotten used to the sbc firing order and am convinced the cylinder ready to fire at TDC has to have both valves closed and both lifters have to be on the base circle.
Something that may help to make a few drawings of the cam lobes and crank rotation and you may be able to see how the crank turns twice for each time the cam & lobes turn. Then follow the crank throws to see how every 90 degrees there are 2 pistons at TDC.
Finally if you need a close look at the cam lopes you can buy USB cameras (endoscope) for your laptop with LED lights on the end. I found one eBay $15 and it works as a poor man's bore scope. I guess what I'm saying is we anxiously await to see/hear what you're cam lobes look like.
Hope this helps and good luck.
http://ls1tech.com/forums/generation...ad-lifter.html
http://ls1tech.com/forums/generation...rior-ls7s.html
see post 29 in the above link.
I believe LS non link bar lifters work in a roller SBC block but I would verify with a good shop or manufacturer.
http://ls1tech.com/forums/small-bloc...gen-i-sbc.html
http://ls1tech.com/forums/lt1-lt4-mo...t1-lifter.html
A good discussion on LS lifters:
http://ls1tech.com/forums/generation...s-welcome.html
I would also call Straub as he is a Morel distributor (most vendors get their Morel lifters from Straub) and a long time SBC/BBC engine builder about setting up the valve train. If I had a ZZ4 needing a cam, the LT4 hotcam is a nice upgrade with OEM reliability. http://www.straubtechnologies.com/
And again, what am I missing ... are those pictures of the lifters from THIS engine currently? If so, why has not the cam been checked NOW? Either by looking at it or simply putting a dial indicator to ascertain travel?
I gotta be stupid..How does valve adjustment affect wiping a cam or a lifter or anything else?....You can adjust them three way...the RIGHT amount of preload, TOO MUCH preload and a valve will not close and the engine will skip, TOO LITTLE preload and it will tick like a SOB. None of these translate into a mechanical failure in my mind. Teach me some more...
Easy tiger, I'm a amateur here just like you and don't have a Spintron Valve Train Analyzer to prove every detail. But let's try and look at to loose first. If pre-load was set while lifter was on a ramp of the cam lobe then very possible slop can occur between the p-rod and lifter/rocker arm and transferred to the valve stem tip. If you can't see how that could hurt metal parts at say 5,000rpm then I'm out here.
Next over tightening the preload collapses and bottoms out the little piston inside the lifter which the starts to hold the valve open. For intake valve that allows exhaust gas back up the intake manifold or for exhaust valve blows mixture out into the exhaust manifold. But worse case the valve is opened so far that when the cam lobe approaches peak the spring retainer hits the valve seal/guide boss.
Now trying to research the cause of this over the Internet is kinda fruitless. Better to just find all the damage and repair. Hey I've wiped lobes before and sometimes learning the hard way is more effective.
Hope this helps.
My nickname is MR Easy Tiger....
I understand all you are saying but what I'm saying if a lifter is misadjusted either way, tight or loose, how in the world does the OP not hear it with his ears [loose] of feel it with his fanny [tight skip]?
Either way...how, within reason, does either adjustment break stuff? Of course I'm not saying 4 turns too tight or loose but how could you even mess it up that much?
Back in the old days, we put clips over the rocker arms and adjusted the valves while the car was RUNNING! [Tick stop and 1/2 a turn]
If I'm wrong...completely not too old to learn from those smarter than me...
We have consider a new enthusiast really doesn't know what to expect or listen for. Once the engine is running the sound of a performance cam is now proof everything is okay though it may not. And now the situation may be the cam (or lifters) are bad enough to break more parts.
Will one more thing since you bought up 1/2 turn pre-load is I used to be a 1/2 turn or less pre-load but discovered that takes away some vlv lift compared to one full turn which is giving up some power. The argument for smaller preloads is it minimizes holding the valve open if you over rev your motor and float the valves. To me that's kinda like expecting failure. Well I use a rev limiter anyways so I'll take the power instead of security.
Hope this can make sense rather than nonsense.
Good night.
I have trouble believing that the cam lobe went flat and that was the cause of the initial rocker arm coming off the pushrod. The #5 rocker arm seem to have full range of motion when the engine was being turned over. I spent a great deal of time setting the lash this last time. I adjusted them. I would think if the lobe were worn to the point that it was the cause of the issue that the rocker would not have full range of motion.
What may or may not be broken at this point is not as important to me as is the initial cause of the rocker coming off of the pushrod in June of 2015. I keep coming back to an oil issue.
I intend to replace the rocker stud. Get a new rocker ball. Put a hole in an old valve cover I have over the #5 rocker and restart the engine and see if I have oil coming through the pushrod at a rate equal to the other rockers.
The rocker ball and rocker arm socket wear is a concern. The rocker arms are case hardened. Once the surface wear penetrates a few thousands, the rocker should be replaced. Wear in the rocker socket or ball can be due to oil starvation or poor startup lubrication. Wear through the hard surface, on startup or over time, and the bearing is shot.
GM may have had a batch of poorly hardened rocker arms, and it is far too late to identify a supplier problem and warranty claim.
New rocker arms, or upgraded roller trunion and tip arms, should be installed.
If, however, the oil volume looks good, I will replace all the lifters and install roller tip rockers.
I intend to take all my broken parts of the #5 and the rocker and rocker ball from #1 (which looks ok to me) to a machinist I know and get his opinion
You replaced the other oil control and channeling parts: the lifters and pushrods. I assume all pushrods were blown out to clean, with a confirmation see through inspection.
If block casting flash or debris is a concern borrow a oil pump priming tool and pump oil to inspect flow to the lifter bore with only the suspect lifter removed, and a lifter on the opposite bank removed. Watch and gage the oil flow (eyeball flow volume). Compare the flow to a lifter bore on the opposite bank and oil gallery. If the flow is the same, the problem is not an oil passage in the block.
If there is a flow difference, rod and brush the oil passage feeding the suspect lifter bore. Look for debris and feel for rough flash catching a pipe cleaner. Do a second oil prime flow test and look for improvement.
Check valve lift at the suspect cylinder with a vernier caliper or dial indicator at the retainer. Measure closed and open height. Intake lift should be the same, same for exhaust lift, for all cylinders. A difference will confirm a worn cam lobe.
Do this before buttoning up the lifter valley. Rule out a problem you will cover up.
My concern is if one rocker arm has wear, the others have hidden wear. If you want to test oil flow at the #5 rocker, ok, but replace all the rocker arms.
Still, I think there is some commonality between the #5 exhaust valve rocker coming off its pushrod first (before I had any involvement) and then after all the lifters and all the pushrods were replaced (where I was totally responsible), the #5 exhaust valve rocker stud snaps off and the #5 rocker ball is worn away.
I like your idea for comparing one oil galley to a different one on the other side. It will make for a nice winter project
This trick in your case is better than using air in the cylinder because you would be able to feel the valve movement without pressure being on it if you lower the piston just a little bit and then raise the piston when you are ready to re install the valve spring.
Something is off or it would still be on the road. Just a couple ideas and I hope they are not off base.
If I am reading and understanding all of this correctly (?) all of the damage has been confined to the #5 rocker area, correct?
Are we just chasing a phantom here which all dates back to the original problem?
IF (big if) I am understanding all of this correctly and if it were my engine, I'd be mighty tempted to just replace that #5 stud, rocker, lifter, push rod etc, put it all back together, and run it for a while.
Easy for me to say 'tho - I know!
"Rocker arm clearance must be checked at several places. It is very common with higher lift cams to have the rocker arm contact the rocker stud when the valve is in the full open position. Be certain to check this, as lack of proper clearance will cause broken studs, broken pushrods or worn-out camshaft."
"The clearance between the rocker arm and the valve spring retainer must also be checked. This problem will be more pronounced when the valve is closed. The retainer is most likely to contact the underside of the rocker arm right in the center. Be sure to maintain at least 0.030" clearance at this point. Pushrod clearance must also be checked, especially when using higher ratio rocker arms. The pushrod seat in the rocker is moved toward the stud in this case, so it must be checked at several different lift points for contact with the cylinder head or guide plate."
How did obtain this pearl of knowledge? From the school of hard knocks! As they say 'Been there, done that and got the T-shirt. But I broke about 5 or 6 pushrods before I read the instructions.
Good luck with your problem.
CJ
