[C1] Fuel Mixture Adjustment
Old Sep 9, 2016 | 02:47 PM
Bomba_MC's Avatar
Bomba_MC
Default Fuel Mixture Adjustment
I have a 58 corvette with a carter carb and the it is running rich. Can anyone offer a advice on how to best adjust the fuel and air mixture?
I was told to close them both off then back each screw 1 and half turns. Can anyone offer some advice. I should mention that I do not have vaccum guage.
Its a 58 corvette 283 4 single carb 4 barrel.
Old Sep 9, 2016 | 03:11 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
yes, those are good starting points. then, without a vacuum gauge, adjust the screw until the idle starts to fall-off and then open just until the idle is smooth.
Bill
Old Sep 9, 2016 | 03:22 PM
Bomba_MC's Avatar
Bomba_MC
Bill
Do I adjust the screw to keep opening or start closing?
Old Sep 9, 2016 | 03:31 PM
prestige6's Avatar
prestige6
Close then open
Old Sep 9, 2016 | 03:32 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
you open to the 1-1/2 turns initially then start closing until the idle falls off/ turns to crap and then gradually open until the idle smooths out. do for each screw.
Bill
Old Sep 9, 2016 | 03:42 PM
tbarb's Avatar
tbarb
Just want to add that it's important when finished to have each side approx. the same turns out. Also, make this adjustment after the engine is warmed very good and the plenum is hot because the fuel vaporizes better.
After you adjust the A/F emulsion screws if you have to re-adjust the engine idle speed it's important to recheck the A/F screws once the idle speed is set. Anytime you adjust the idle speed the A/F ratio changes slightly so a quick check of the side screws is a final tweak.
Old Sep 9, 2016 | 06:46 PM
SWCDuke's Avatar
SWCDuke
From the initial adjustment of 1.5 turns out from the seat turn each screw clockwise in quarter-turn increments. When idle quality/speed drops go back out 1/4 turn. That will ensure that both screws are out the same number of turns. Then try 1/8 turn increments.
It should probably end up somewhere between 1 and 1.5 turns out, equal on both sides.
Duke
Old Sep 9, 2016 | 11:33 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Are you trying to tune just the idle mixture? Or do you want to tune the entire power band including cruise and WOT? The idle mixture screws adjust the idle mixture only . For acceleration you have an accelerator pump and then primary jetting for cruise with secondary jetting for WOT - depending on which carb you have.
FYI modern method of tuning the entire carb uses an air to fuel monitor. Getting pretty cheap these days and they take the guess work out of rich or lean. BTW a vacuum gauge is cheap as pocket change and I don't see how you can do much old school diagnostics w/o on.
Let's us know if you need further help here. One more thing, myself I could never get a four barrel carb idle screws to adj using just RPM. I always seemed to chase the screws and RPM w/o consistent result.
Good luck.
Old Sep 10, 2016 | 05:18 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I stopped reading this at the first post when the OP stated he didn't have a vacuum gauge. Trying to do diagnostics and tuning on a car without this $20 item is just making your life harder for no reason. After the OP gets the proper instrumentation then I'll believe he really is interested in getting his car running properly.
From the WCFB Service Manual:
Old Sep 10, 2016 | 07:20 AM
cardo0's Avatar
cardo0
I was thinking the same but went and replied anyways - maybe a little bored and couldn't get to sleep. But let's see if he participates. This is good topic and can be fun to learn more or better methods.
Oh well.
Old Sep 10, 2016 | 07:29 AM
Frankie the Fink
Army
I'm about as old school as it gets but you still need the instruments. I tune my carbs with tach/vacuum gauge and do a final tweak by walking to the rear and putting a palm up to the two exhaust pipes... If the idle is uneven, loping slightly, or, occasionally 'dropping shots' I adjust the mixture screws every so slightly to eliminate that. Sometimes its just a 1/16th of a turn on a mixture screw to get perfection.
That procedure gets lots of funny looks though...
Old Sep 10, 2016 | 12:05 PM
Bomba_MC's Avatar
Bomba_MC
Well, I respect your opinions, however I am no mechanic. I am just trying to learn about this car and do what I can. That being said, let me ask where does this vacuum gauge get attached ( a pic would help) and what reading I am looking to achieve?
Old Sep 10, 2016 | 01:12 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
The vacuum gauge wants to measure manifold vacuum. You need to "T" it into the vacuum advance (or perhaps PCV line, or unused vac port).. The measurement itself is not important, you are just looking for 'maximum' vacuum.
But back to the main point... as Cardo said.. these screws only adjust the idle mixture. If the car is 'running rich', it's not going to effect it. You might have a problem deeper in the carb??
What makes you say it's running rich?
Old Sep 10, 2016 | 01:20 PM
Bomba_MC's Avatar
Bomba_MC
Strong smell of gas from exhaust and build up of black carbon on the exhaust pipes. I guess i just need to start somewhere. I notice those screws A/F were open quite a bit.
Old Sep 10, 2016 | 02:18 PM
Bomba_MC's Avatar
Bomba_MC
I also want to add that I now have a vacuum pressure gauge in hand.
Old Sep 10, 2016 | 04:05 PM
Frankie the Fink
Army
I wasn't belittling you, but, you now have one of the best diagnostic (and cheapest) tools in your hand for these old motors that you will ever own. Yes, "T" into the vacuum advance rubber line and you may want to spend some time with the scenarios at the bottom of this web page to determine what it normal and what is abnormal and the various causes. If you learn just those; you'll know more than at least 20% of the folks on here...
http://www.secondchancegarage.com/public/186.cfm
Once you've learned what normal is you can tune the mixture screws (alternating between the two) for the smoothest idle at the highest vacuum.
Your symptoms may, or may not, indicate a rich mixture. Many times these old cars smell of fumes when running and black, chalky deposits in the tailpipes are absolutely NORMAL...
Your spark plugs and general performance are your best indicators of air/fuel ratio..
Old Sep 10, 2016 | 10:47 PM
Bomba_MC's Avatar
Bomba_MC
Well now that I have the gauge, I am asking myself where do I connect it? After reading the article provided by Frankie, I see that the hose and adapters with my gauge are much smaller than some of the vacuum hose I am looking at except for the one coming off the carb feeding the distributor. BUT, if I understand this correctly, using that vacuum connection is not the appropriate connection for idle. So my question is, which vacuum connection can I use that will provide the readings I need at idle. Can anyone provide me with that information or a picture showing the actual gauge connected?
I am trying to learn but want to learn and perform these tasks accurately. I know most here are seasoned mechanics and I hope to someday be able to share what I have learned with newcomers to the corvette world. I thank you all for your patience with my ignorance in this field.
To Fuel Mixture Adjustment
Old Sep 11, 2016 | 06:36 AM
Frankie the Fink
Army
The line coming off the base of the carb to the distributor (vac advance) will work fine if it is FULL vacuum....if you hook up your gauge there and get any reading from 10-21 its fine to use.
Old Sep 11, 2016 | 01:40 PM
Bomba_MC's Avatar
Bomba_MC
Now is this where I use that T type connector for the hose to the distributor and the hose to the gauge coming from the base of the carb?
Old Sep 11, 2016 | 02:18 PM
Frankie the Fink
Army
Yes.
