starter tips
Old Sep 13, 2016 | 01:29 PM
old68's Avatar
old68
Default starter tips
need to put a new starter in my 65 327 roadster, anyone have any good tips or points? any help would be great, thanks a bunch, and yes disconnect battery 1st
Old Sep 13, 2016 | 02:08 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
if you are not into 'originality' you might want to try one of the mini-starters; a lot easier to deal with....
Bill
Old Sep 13, 2016 | 02:43 PM
65 vette dude's Avatar
65 vette dude
Powermaster 9202 still has the "R" terminal on the solenoid, if you have points ignition..... and their 9100 is a good choice if you have electronic ignition. They both are made in the USA, and both are gear reduction, and weigh about half of a stock starter.
Old Sep 13, 2016 | 02:47 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Have your old starter rebuilt...
If you need new plug wires now is the time to do it and route them through the shielding with the starter out of the way...
Old Sep 13, 2016 | 04:58 PM
old68's Avatar
old68
Default too late on the starter
too late , I already got a replacement starter from corvette central,
Old Sep 13, 2016 | 05:14 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
you sure didn't wait long for 'tips'
Bill
Old Sep 13, 2016 | 05:47 PM
leif.anderson93's Avatar
leif.anderson93
Bill
Think he's looking for R&R tips...not tips on which one to buy
Old Sep 13, 2016 | 06:34 PM
Bowtyeguy's Avatar
Bowtyeguy
Its pretty easy, just dont let the starter hang there or the small wires will probably snap off, support the starter, so it doesnt fall on your head.Remember where you took the wires off , on the ground its a half hour job , n there air 15 tops. 2 Bolts and maybe a starter support.
Old Sep 13, 2016 | 07:05 PM
Frankie the Fink
Army
A few smartphone pics before you ****** the old starter off will keep you out of trouble. I find with my failing memory I use that technique more and more.
Did I tell you about the smartphone -- I don't remember ?
Old Sep 13, 2016 | 07:49 PM
vark_wso's Avatar
vark_wso
old68
Going back to your request for tips/points ... this might be a good opportunity to install a fusible link on the 12 GA feed to protect your wiring harness.
If you have undercar exhaust system, a similar opportunity to afford some radiant heat protection would be to modify the starter's debris shield with some insulation. In the photos below, I fashioned a larger surface to cover/shield the whole solenoid.
Old Sep 13, 2016 | 07:51 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
gee... I thought changing the starter is a no-brainer....
as far as starters; there are at least 3 different types that I know of: standard, heavy duty, and mini...
Bill
Old Sep 13, 2016 | 07:56 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Bill
To those people they would have dropped it off at a local rebuilder, or bought the rebuild parts at the parts store or very lest bought the starter from the auto parts store.
Old Sep 13, 2016 | 07:59 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
If you find any shims between the old starter and the motor, reuse the same amount with the new starter and you'll usually be correct on the clearance. If it's binding you'll usually hear it.....loud ugly noise instead of the usual.
I always put a little bit of white lube on the bendix drive gears, spring, and shaft mech for ease of movement.....not too much though, don't need any grease flying around your clutch.
I also recommend the small head ARP starter bolts that are knurled for exact placement of starter.......
Old Sep 13, 2016 | 08:05 PM
Mikado463's Avatar
Mikado463
Bill
LOL Bill, I thought the same thing !
Old Sep 14, 2016 | 04:03 PM
Powershift's Avatar
Powershift
One of the easier jobs. Should have both a starter heat shield and a starter brace. Two bolts into the block with special knurled starter bolts.
Take your time on the wiring and get it right the first time. Don't forget the wiper motor and blower motor ground on one of the two starter bolts.
Just make a few notes before disassembly, and then check to make certain that the previous owner actually installed it according to the electrical drawings. I know on my car, ALL the wiring in this area was a mess........and most of my time was spent correcting it. If needed, these wires can be pulled up to the top of the fender area so you can work on them and/or solder connections without being on your back.
Larry
Old Sep 14, 2016 | 05:14 PM
Bowtyeguy's Avatar
Bowtyeguy
The best part is just take a pic with your phone so you can remember where stuff goes.
To starter tips
