Ignition wiring
Old Sep 15, 2016 | 04:34 PM
drlou's Avatar
drlou
Default Ignition wiring
I removed my cluster for restoration and decided to try the LED replacements. When I went to test them all I figured I would just put 12v to the run circuit off the ign. switch(since the battery is disconnected). I noticed that while the elec. diagrahm shows a ground terminal in addition to 12v,solenoid,accessory,and 2 spliced wires to ign.(?) there was no wire to the ground terminal. The car ran fine before I pulled it apart and has been changed to an MSD ign. Why no ground? Thanks. Oh, and I couldn't get the LED's to fire up even with the ground from the 12v source attached to the dash frame. All the LED's work.
Old Sep 15, 2016 | 05:04 PM
buns's Avatar
buns
You need to put 12 volts to the "Batt-Power Window" terminal as shown in the picture below. The ground terminal on C2 ignition switches was not used.
Old Sep 16, 2016 | 03:27 PM
drlou's Avatar
drlou
Thanks for your help.
To Ignition wiring
