tele column install
tele column install
I'm preparing to install a stock tele column in my 65. Can someone tell me where to orient the column rotation when installing the spline, with the front wheels aimed straight so that the signal light cancel cam will function properly.
Received 6,993 Likes
2015 C2 of Year Finalist
there is a flat spot on the splined end of the column where it goes into the rag joint that also has a flat spot. it can only go in one way. also on the inside shaft where the hub mounts to is a index line that points up that matches a indexed line on the hub
