63 Tach
Old Sep 27, 2016 | 12:04 PM
ERS1963's Avatar
ERS1963
Cruising
Default 63 Tach
Recently my tach stopped working with the needle stuck on 2500. Can I assume that it is an internal gauge issue and not a cable or dizzy drive issue?
Old Sep 27, 2016 | 12:08 PM
66jack's Avatar
66jack
Take if off at Dis. and check...
Then you'll know if its the cable...then go from there..
Old Sep 27, 2016 | 01:01 PM
ERS1963's Avatar
ERS1963
Cruising
That is easy enough to check i guess, assuming my drill is charged up.
Old Sep 27, 2016 | 01:04 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
There is no mechanical connection between the cable and the tach needle. The coupling is entirely magnetic and depends on the rotation of the cable to exist.
If the tach needle is frozen on any RPM, the tach mechanism has a problem.
Jim
Old Sep 27, 2016 | 01:32 PM
ERS1963's Avatar
ERS1963
Cruising
Jim
That was my assumption, that the gauge needed to come out for inspection.
To 63 Tach
