Power Windows
Old Oct 1, 2016 | 10:30 PM
my63vette's Avatar
my63vette
Default Power Windows
So I have power windows on my 63 Roadster that I recently purchased and the drivers side window doesn't work. Today while under the dash I noticed the fuse block (see pic) where only one of the two designated slots for "power windows" was utilized. Is this my problem or is this the norm.
Old Oct 1, 2016 | 11:17 PM
buns's Avatar
buns
That is normal, it's the power supply for the power windows. If you follow that red wire it will end up at a circuit breaker for the window motors. Also, that power supply is hot all the time, even with the key off, so be careful.
Old Oct 1, 2016 | 11:21 PM
my63vette's Avatar
my63vette
Okay. I guess I need to look at the motor and see if it's shot.
Thanks for the reply
Old Oct 1, 2016 | 11:47 PM
buns's Avatar
buns
It's quite an ordeal to get to the motor, I would start by checking the switch and the wiring running from it to the motor.
Old Oct 2, 2016 | 09:45 AM
morly1963's Avatar
morly1963
My windows stopped working on my 63 after 20yrs. Took out the switch and cleaned it. They work fine now.
To Power Windows
