Sequential transmissions
Sequential is just the way the trams is shifted verses an "H" pattern.
If the sequential trans has a shift lever, you just keep pulling back for each gear. The shift lever (in race cars) pulls a cable that's attached to the trans shift lever. This spins a drum in the trans that is the same design as a bike trans. The shift forks are moved by that drum vs having shift levers that move the shift forks in an H pattern (like a stock Muncie).
Sequentials can also use an air or hydraulic cylinder, , electric solenoid to actuate the shift lever.
The first pic shows the shift mechanism in one of our Formula Atlantics, the second shows the shift drum on the left side that runs the shift forks. The gears at also a dogring setup (no syncros).
Sequentials shift faster than an H pattern but only because you move the shifter a tad over an inch to change gears.
If you want REALLY fast, you need a double clutch system.
Lou G. Motorsports sells real sequential trans axles for C5-6-7's but you need a really fat wallet to buy one.
my Mercedes built Smart has a transmission like that, plus paddle shift, plus bump shift.
Bill
Note that both are also transaxles not just transmissions.
The MTI is a sequential manual for C5,6,7.
Costs for a paddle shift setup on a manual isn't a big deal when you are looking at a transaxle that costs $22k +.
All you need are the paddles and a couple solenoids to run the shift lever.
A friend of mine just bought a Wolf race car, it's a 6 speed sequential manual with paddle shifting. The paddles just have a momentary switch on each one. The shift lever on the trans is run by an electric push/pull solenoid, very simple.
Bill
at least you could 'skip a gear' (which I do a lot in everyday driving (2nd to 4th or 3rd to 5th)...)
Bill
I like the paddles, even in automatic mode, if you start pulling paddles, it goes into temporary manual mode.
If want to waste 20 minutes, watch me drive at Spring Mountain.
This was all in manual paddle shift mode.
Doug
Neither Ferrari or Lambo produce regular three pedal transmissions any more.
The C 7 is an automatic transmission that can be paddle shifted. Also fast shifts as seen in the above video on track.
Even Lambo states that they do not offer a manual any more.
Put it in automatic and it does it's normal driving operation.
Put it in manual and can be shifted with the shift lever or paddle shifter.
The paddle shift was a PITA.
