1963 split value
Old Oct 8, 2016 | 06:48 PM
d69302's Avatar
d69302
2nd Gear
Default 1963 split value
I recently came across a 63 split window for sale. I had some? About what it might be worth. The car is a project, original engine gone,has a shark style front clip, but has a replacement front clip from a donor car. Birdcage has a little scale but appears to have no holes , frame has soft area at the kickup on both sides . I think the car was the 340hp version. The rest of the body looks good no damage has orig 4sp and rear axle . A 68 rebuilt 427 also comes with, not sure of hp on it . The car has been sitting in a garage for about 30yrs. I know the spilt window cars are desirable now , the big issue I have with the car is the trim tag.:the car has a 1964 trim tag on it . The vin tag is a 63 , the owner has no idea what happened, he has had the car since the early 70s .I know you can get a replacement tag, but how much would this hurt the value if car were restored? The owner will go no lower than 20 for it .
Old Oct 8, 2016 | 07:32 PM
Bowtyeguy's Avatar
Bowtyeguy
If you really want a 63 and willing to do the work yourself 20k is an OK deal. As long as the Vin is the correct one I would just leave the trim tag as it is and drive it. Its only going to give you a problem when you go to sell it. I think you will be upside down in it by the time you are done with frame issues and unknowns.
Old Oct 8, 2016 | 09:27 PM
C2 Hot Cam Guy's Avatar
C2 Hot Cam Guy
Default 63 vin
Bow tie guy is right make sure the vin is not tampered with & matches the frame . I saw one that had 1 # from another vin glued on top of original was hard to spot i almost bought that car
Old Oct 9, 2016 | 08:34 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Sounds like a Frankenvette. IF, repeat IF, a lot of the one-year-only
parts are there, it may be worth $20K all day long to piece out....
I think you would be underwater so fast if you tried to 'bring it back' your head would swim and then when its all done have a questionable provenance...
Old Oct 9, 2016 | 12:17 PM
rfn026's Avatar
rfn026
I see big time problems If you found a little rust you really have a lot of rust. Rust is like an iceberg.
The second problem is you picked a tough car to rebuild. There are a lot of one-year parts.
Just give up on the idea of restoring this car. A restoration might easily be $150,000. Probably more.
You could have a driver though. A hot-rod. You're going to be way upside down on this car but you'll have a lot of fun. The dues at my golf club are $10,000 a year. Spending $10,000 a year on a Corvette is a lot more fun than golf.
The rust does sort of scare me though.
Richard Newton
Garage Fires
To 1963 split value
