help with engine
the number on back is 3955270 and the vin number in the front is TO3497BB the heads are alum 3946074 and the intake is alum 3933163. What is the engine and what did it go in. Please
thanks
TO3497BB doesn't make any sense.
The block casting number and head casting numbers work for 1969 vintage parts.
The intake manifold looks like if could be a 1968 / 1969 vintage part.
Please post a picture of the front engine pad.
It seems the BB is the concern. I have tried to research the internet and can not fine this code. The block is for sure a 69 HP block according to all the numbers and the heads and intake is correct for a L88 but the front is a problem
thanks for your help.
I suspect that you engine code stamp is 7BB. A number of marine engines used a engine suffix code that started with a digit.
Another possibility is a rebuilder's stamp.
Seeing the stamp will help make that determination.
The problem with the engine stamp, goes beyond the "BB". There's to many numbers in the stamp.
The "163" intake you have, was not used on the L-88. 68-69 L-88's used the "198" intake, and 67's used the "069". The "163" intake was used on 68-69 396/375's in Camaro's, Chevelle's and Nova's, as well as the 69 427 COPO Camaro's.
A look at the stamping, might help identify what you have. Big blocks made for marine applications, had a 3 digit suffix code, made up of a number followed by 2 letters. Unfortunately, I can't find any listing for a "7BB" marine suffix code. The vast majority of marine big block suffix codes had an "X" as the second digit, with "F" and "H" as the other most common second digits. There were no marine big blocks that had a "B" as the second digit in the suffix code.
TO3497BB
T = Tonowanda (possibly)
O = is this a letter 'O' or a digit zero. let's assume digit zero
3 = March (month of assembly)
49 = oops, there are not 49 days in a month, any month
7BB = suffix code ???
Look at it another way
O = is this a letter 'O' or a digit zero. let's assume letter 'O' = ???
34 = oops, no month of 34
97 = oops, there are not 97 days in a month, any month
Seriously, a picture of this engine pad will help a lot.
