Another Engine ID ?
Can anyone decipher this engine pad number?
T0905DNH It came out of an El Camino. I am pretty sure it is a 305 C.I. I don't think it is the original engine to the car. The date code is J2477 which it think is Sept. 24, 1977.
Any help is appreciated.
Larry
1967 Chevelle 283cid, HD Clutch. 195hp DN
1968 Chevelle 307cid, HD Clutch. 200hp DN
Found it here..The "H" stands for Holley Carb...When you put in the code leave off the "H"...
http://www.thecamaro.com/Decoding/Ch...inedecoder.php
J = October
24 = 24th day
66 / 67 / 77 = 1966 or 1967 or 1977
T = Tonawanda
09 = September
05 = 5th day
DNH = engine suffix code
My issue with this is that the engine assembly date (September 5th) is well BEFORE the block casting date (October 24th).
Please confirm the block casting date, and perhaps provide the block casting number as well.
What year El Camino did the engine come out of?
Assuming alll of your information is correct, then the most likely scenario is that the engines block was cast Oct 24, 1977, and the engine was assembled Sep 5, 1978 (11 months later).
This is not common, but long delays did happen for things like an engine needing heavy repair. If so, it would have went to the heavy repair section, and could have sat there a while.
If it is a Sep 5, 1978 assembly, then what you have is a 1979 305, 130 hp, 2bbl, automatic, installed in a 1979 Camaro. September would be the second month of production.
Is there a VIN derivative on the engine pad? What color is the engine, orange or blue?
