Help decoding differential numbers
Old Oct 30, 2016 | 05:02 PM
jfr's 63swc's Avatar
jfr's 63swc
Default Help decoding differential numbers
The differential is out of a late '63 convertible.
The numbers on the front of the main case are 3899143. The date code on the side of the front nose of the casing is C 2. On the bottom of the casing is AWW 065 E 1.
The rear cover is 3830308 with GM4.
From some goggling, it appears that the rear cover is indeed off of the '63, however, I can not figure out what the main case came out of.
It does appear to be 3.08:1 based on turning the driveshaft input one revolution and counting the turns on the half shaft output.
Thanks in advance for the help!
Old Oct 31, 2016 | 08:40 AM
jfr's 63swc
Maybe some photos will help with some replies!
Old Oct 31, 2016 | 09:03 AM
66jack's Avatar
66jack
I just looked in my GM parts book and cannot find that number for the main case...are you sure about the number as i cannot make it out from you photo?
The only "number" in my book is 3917861 for 63-72
It could be a latter case...
Old Oct 31, 2016 | 09:08 AM
BKarol's Avatar
BKarol
my guess would be:
AW= 3.08
W= Warren plant
06= 6th day of year
5= 1975
E= Eaton
1= 1st shift
Old Oct 31, 2016 | 11:20 AM
jfr's 63swc
Thanks for the response. The number is correct. From googling it, it appears it is out of a later '70s corvette. Trying to see if it might have been used in other cars as well.
Ultimately I want to determine how beefy it is and how much HP it can handle!
Old Oct 31, 2016 | 11:22 AM
jfr's 63swc
Originally Posted by karol
my guess would be:
AW= 3.08
W= Warren plant
06= 6th day of year
5= 1975
E= Eaton
1= 1st shift
Thanks for the response. Any idea how the "C 2" on the front nose (which I thought was the date) relates to the assembly date?
To Help decoding differential numbers
