56 corvette grille
Old Oct 30, 2016 | 07:06 PM
rleis's Avatar
rleis
5th Gear
Default 56 corvette grille
Can someone help me with the order on the teeth for the grille? Does the smallest one go in the center or ?
Old Oct 30, 2016 | 07:10 PM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
The teeth are numbered inside.
Google "Corvette Grill teeth " and you should be able to find a diagram.
The center tooth is different from the others.
Old Nov 3, 2016 | 06:24 PM
rleis's Avatar
rleis
5th Gear
Default Heater valve placement
I have a 1956 corvette which was purchased as a basket case. The heater box in the car was not original. I have purchased the original, but I can't figure out where the heater valve mounts on the car. Can someone help me out with a description or photo?
Thank you in advance.
Ron
Old Nov 3, 2016 | 09:53 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The Grille teeth on you car are installed in this order from outer edge to outer edge.
6 5 4 1 1 1 C 1 1 1 4 5 6
This was the same for all cars 1953-1957
Here is the heater valve from the AIM in 1957
Old Nov 4, 2016 | 09:50 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Correct.
To 56 corvette grille
