62 vette , 327 ci distributor won't go in all the way???
I have a '63 that the distributor will not go in all the way. Goes all the way in but about 1/4 inch or so. I have alligned it with the oil pump and it seems to be alligned ok. I have tried it multiple times to no avail. Any ideas????BTW, 327 ci engine with original distributor and have put it it several times before with no problem. I did replace the distributor shaft with a new one because of the tachometer gear being badly worn. HELP
Remove the ignition coil wire and 'bump' the key with the car in neutral a few times...the distributor will sit right down for you....you can even watch it happen through the windshield..
You can usually snug down the hold down clamp a bit to keep it from jumping...I've done more times than I can remember....the other methods is the Lars 'walking' method....which has been well documented here before...
I'm going to tell on myself. I rebuilt my 63 distributor and when try to put in engine, it would not go all the way in. I messed with that thing till I was blue in the face. I was almost ready to drop the pan to see if something was in the way when I decided to place another dist I had next to the one I rebuilt. After studying them both I said WTF, I had install the bottom gear upside down. After removing the gear and installing it correctly, dist slid right in.
Received 1,549 Likes
My first thought. Don't ask me why...
kinabub (11-12-2016)
Did exactly the same thing when installing my distributor - could not believe I had such a brain fade. .
