65 speedometer
Old Nov 8, 2016 | 07:06 PM
65 396's Avatar
65 396
Default 65 speedometer
The speedometer on my 65 reads fast. In other words, when I'm actually going 60 mph, it reads 65 mph. I know I need to remove the plastic gear but do I need to go 1 tooth more or 1 tooth less for the new gear?
Old Nov 8, 2016 | 07:16 PM
66jack's Avatar
66jack
Whats the diameter of your tires...that a variable that you need to take in mind...'size matters'...
Old Nov 8, 2016 | 07:21 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Quick answer... you need a gear with more teeth to make the speedo spin slower.
65/60 = 1.083
If you have a 26 tooth gear in there now, you'd need a 28.xxx tooth gear to slow it down.
26 x 1.083 = 28.xxxx
Chuck
MikeM's Avatar
MikeM
Without knowing exactly what metal gear is on your mainshaft, your rear gear ration and your tire size it's impossible to recommend the right combination accurately.
That said, you can try one more tooth on the plastic gear and that should slow down your speedometer about 3 mph. That's if the gear doesn't shear due to mismatch with the steel gear.
Old Nov 8, 2016 | 09:02 PM
buns's Avatar
buns
Info:
http://chevellestuff.net/tech/speedo.htm
To 65 speedometer
