Horn Problem
Old Nov 12, 2016 | 10:23 AM
nasteve's Avatar
nasteve
Default Horn Problem
Working on a 66 roadster. Horn starts blowing as I am driving down the road without me touching anything. Removed the horn button from inside the steering column and it still blows. What could be the problem? Relay???
Thanks for any help,
Steve B
Old Nov 12, 2016 | 10:27 AM
66jack's Avatar
66jack
You have a 'dead' short somewhere...
Have checked anything yet?
Old Nov 12, 2016 | 02:02 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
The black wire from the horn contact, going thru the turn signal switch, bulkhead connector to the relay is the culprit has a short to ground somewhere.
The horn contact button only serves to complete the path to ground for the relay and toot the horns.
Old Nov 13, 2016 | 06:56 AM
nasteve's Avatar
nasteve
Thank you for your reply. No, I haven't checked anything yet, where should I start?
Old Nov 13, 2016 | 07:10 AM
66jack's Avatar
66jack
vette2002 gave you the starting point...check that black wire...also check the 'brass' plunger that could be hanging up...
To Horn Problem
