Ballast Resistor Y/N
Received 6,943 Likes
2015 C2 of Year Finalist
RON
T.i. Resistors
Nope, that resistor is the white resistance wire that plugs into the pink wire that comes from the ignition switch. It's part of the T.I. harness. In a non T.I. car, that pink wire connects to the bottom of the ballast resistor. That's the main power feed for the ignition system---T.I. or non T.I.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The function of the ballast resistor/resistance (swap the names around if you like, but it's the same electrical function in the circuit) is to limit the primary current through the coil. That's what R7 and R8 do (and also the reason for the R label on both of them).
The OP asked about the external ballast resistor that is mounted on the firewall for most cars. TI cars do not have it, but do use other means to provide electrical resistance in the ignition circuit.......they use special lengths of wire with known/calculated resistance or internal resistors in the circuit boards.
How far do we want to take this??
Larry
Larry
Location: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Larry
Larry
The OP asked about the external ballast resistor that is mounted on the firewall for most cars. No he did not. He never mentioned any of that in his post. He referenced only ballast resistor and TI ignition. You inferred content that the OP did not state in his post. TI cars do not have it, but do use other means to provide electrical resistance in the ignition circuit.......they use special lengths of wire with known/calculated resistance or internal resistors in the circuit boards.
Yes, as I stated in my first post.
Larry
Larry
