Clutch Cross Shaft
Clutch Cross Shaft
Guys,
I'm rebuilding my Clutch Cross Shaft and I was wondering what type of grease is used in the shaft?
I finally took it apart and the frame stud and retainer ring looks fine, so I'm not replacing them. I am going to replace the engine stud and nylon ball seats.
One gripe I have is the guy I bought it from put everything in buckets and didn't label anything. As a matter of a fact, he left the buckets outside and most of the bolts and parts have rusted. What a pain!!!
Thanks,
58n65
Thanks,
58n65
Received 6,986 Likes
2015 C2 of Year Finalist
Chassis grease of any color will work
58n65 (12-20-2016)
Guys,
Thanks,
58n65
Thanks,
58n65
Grease. Like Nowhere said, any color. You are never moving it fast enough to be an issue.
All of what in buckets? There are only a few pieces to the cross shaft.
Thanks guys for the grease help....just wanted to be sure.
58n65
Received 1,921 Likes
Sounds like a great rationalization to get a sand blasting cabinet.
on my 59 I had a zerk fitting installed on the shaft so that I can grease it. What I DIDN'T do, is some guys put a channeled wooden dowel in there to take up the space, otherwise you will have to put a LOT of grease in the shaft. I'll do that the next time.
Okay, to complete the thought: A blasting cabinet should be able to save you the costs of replacing lots of little fiddly bits, since you would be able to clean them up instead of ordering new ones, plus they would have a better chance of being originals, if that matters to you.
Secondly, having a blasting cabinet would save hours of tedious hand cleaning of old grungy parts, which would free you up to work on more important stuff.
There it is.
There it is.
Received 1,974 Likes
A full synthetic NGLI #2 like Mobil 1 is good for just about everything - wheel bearings, u-joints, steering gear, and all chassis lube points including the clutch cross shaft. The only other grease you need is white lithium for door and hood latches.
Duke
Duke
Thanks,
58n65
There it is.
There it is.
Thanks,
58n65
Did I mention he put that damned gunk in my distributor, too? I wondered why I was having so much trouble with ignition timing until I figured out the breaker cam was "glued" to the distributor shaft with dried lithium grease.
58n65 (12-21-2016)
I have a five gallon pail of Evap po rust in my workshop. 48 hous in that stuff and all the small rusted scrapy stuff comes out like new. A combination of a bead blaster and evap po rust make life a lot easier during a restoration.
