Date codes
Old Dec 24, 2016 | 05:09 PM
redvette427's Avatar
redvette427
Default Date codes
Trying to figure out how original my 66 Vette is. I have some pictures of the transmission, rear end, bell housing and the build tag. I would appreciate any help figuring this out. Thanks Bob
Old Dec 24, 2016 | 06:00 PM
rtruman's Avatar
rtruman
Look like the engine date is May 19,1968
Old Dec 24, 2016 | 06:12 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
where you getting a engine build date?????
Trim tag decides too:
C20= Nov 20th
66 467= 66 convertible
Trim Std= black vinyl interior
? 1377 = the ? should be a "A" for A. O. Smith or "S" St. Louis and the 1,377 convertible body built at either plant
974= Rally Red exterior upper and lower
rear end not sure on that casting date. but what you do want to find is the build suffix code and date which is stamp on the bottom machined surface between the strut rod bracket and spring plate.
621 bellhousing was used on 67-? 11" flywheels used on most BB chevy cars
the trans casting number is typical for 65-6? Munices all applications
Old Dec 24, 2016 | 06:18 PM
vettebuyer6369's Avatar
vettebuyer6369
He's getting it here, I imagine:
Old Dec 24, 2016 | 06:21 PM
Nowhere Man
that is a rear end case. note the pinion flange
Old Dec 24, 2016 | 06:36 PM
redvette427
C20= Nov 20th
Would that be Nov 65? Car is a 427. I am heading back down to look for the rear end numbers. Thank you!
Old Dec 24, 2016 | 06:48 PM
Nowhere Man
Yes Nov 20th 1965. Production started in aug 65 and went to July 66
Old Dec 24, 2016 | 07:07 PM
redvette427
Rear end numbers hard to read with my eyes but looks like H 22 last number is a 5, 8 or 3 lol I cant make it out.
Old Dec 24, 2016 | 08:44 PM
Nowhere Man
try and get a good clear picture.
also for the trim tag date code seeing how I can't make out if its a Smith or Louis body the C could be Oct for Smith tags or Nov for Louis tags
Old Dec 24, 2016 | 09:00 PM
redvette427
serial number 194676s104421
Old Dec 25, 2016 | 07:07 AM
rtruman's Avatar
rtruman
yea thought it was a picture of engine cast date ,Still I don't think its a 327
Old Dec 25, 2016 | 07:41 AM
Nowhere Man
The op never said in is original post he was showing a picture of his engine stamp or casting date. In the order of his pictures and his questions he's showing a casting number or date of the rear end housing. Further more the op said his car is a 427. And merry Christmas
Old Dec 26, 2016 | 05:03 PM
redvette427
Engine block casting 3869942
Does pad look like a re-stamp?
Old Dec 26, 2016 | 05:07 PM
redvette427
Surface looks milled with a face mill to me no broaching paths.
Old Dec 26, 2016 | 05:31 PM
Nowhere Man
Use a chemical stripper to remove the paint and take some more pictures. Do not use any mechanical means to remove the paint.
Old Dec 26, 2016 | 05:32 PM
Nowhere Man
Also get the casting number of the block
Old Dec 26, 2016 | 05:37 PM
redvette427
block casting # 3869942
To Date codes
Old Dec 26, 2016 | 06:23 PM
Nowhere Man
Something's not adding up the casting date is Augest 10 1967. But the 942 block stopped being cast sometime around June/July 66.
Old Dec 26, 2016 | 07:53 PM
redvette427
Picture by oil filter
Old Dec 26, 2016 | 08:08 PM
redvette427
Yes sir. I have been doing some research and I can not find this block being used anywhere in 1967.
