bbc manifolds.
bbc manifolds.
I'm thinking of putting a bb in my 67. I see two styles of manifolds for sale to supposedly fit. the long swept down style and what looks to me to be bbc camaro style rear discharge.. do both styles fit? or just the first choice.
Received 6,946 Likes
2015 C2 of Year Finalist
65-74 should be all the same with some minor differences
https://www.paragoncorvette.com/p-35...nifold-lh.aspx
https://www.paragoncorvette.com/p-35...nifold-rh.aspx
BBC Corvettes had their own unique exhaust manifolds. The ones Nowhere man linked to are the ones for Corvettes. Camaros, Chevelles, Novas and full size passenger cars had a different style manifold. These manifolds might physically fit in a vette but factory style exhaust pipes won't fit to them. Not to mention they don't flow as well as vette manifolds. See the difference for yourself.
https://www.yearone.com/Product/1967-81-camaro/bb396
I once owned a 425 HP 4 speed 66 Caprice and the engine was basically the exact same as a Corvette 425 HP. Fun car.
the rest
so my next question is going from a small block to bbc (early 80s 454) when i set it in and try to reuse my power steering pump and a one wire alt , (fan is no issue I have a becool system) does the short water pump get used because of the p steering pump to frame clearance ? and lastly do I try to find all bbc pulleys and brackets for a 67 because of that p steering pump ? or do i just use a long water pump and mid 80s brackets and pulleys ?
you MUST use a short water pump with all the 65-74 pulleys and brackets
If you don't want to change your radiator support you can use a '65 396 or an L88 radiator, thermostat housing, fan shroud and radiator hoses.
Thanks to Critter1 for the tip on full size 427/425 cars. They weren't exactly the most common things.
