Hello,
I have a 1961 I recently purchased and am starting to fix a few things on it. The door gap at the back of the passenger door opens up to about 3/8" at the top and doesn't look great so I would like to close that gap a little. Doing a search on the forum, it appears I may be able to shim the body behind the door to help close the gap. I have attached pics and want some opinions if shimming may help, and also, where to shim exactly.
Thanks,
Jon
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Shimming will probably help. The bolt you need is down in the right rear fender well. Looking underneath the car, you'll see the bolt coming through the body where it bolts up to the rear crossmember. Remove the bolt and jack the body up on that side and install shims between the frame and body. Be gentle. You might find some rust in the frame causing it to sag.
Check the body mount in the rear of the passenger compartment
make user it is not crushed or damaged
you can shim the rear body mount and the rear passenger mount to adjust your gap
careful as it may change your trunk gap
What does the other side look like
Have someone drive your car down a road with some longish bumps like drainage channels or uneven pavement (not potholes), while you sit in the passenger seat and look at that door gap change going through those bumps.
