Question for the engine guys
Bill
btw, I like 'blue' better, and I have a red car....
But yeah, the tests went from four to six questions with the intro of calculators.
Doug
That would show the additional distance that the wrist pin/piston moved downward. If not, I'll try to draw a pic and scan/post.
That should make it easier to understand why pistons move further and faster in the 1st 90° of C/S rotation.
While this math seems academic, the value is in predicting the dynamic compression ratio when the intake valve closes on the compression stroke (or in my initial education, the roof of the exhaust port of a 2-stroke is blocked by the top ring as the piston rises). If the intake valve closes at 90 degrees before TDC, the cylinder can experience more than 1/2 of the static compression ratio (dependent upon the chamber volume). The dynamic compression ratio at the point of ignition is critical to design around detonation and to idealize the spark advance map. In the design of a Diesel it determines the rpm where compression ignition provides maximum combustion efficiency and torque.
During my youthful motorcycle focus I was all wrapped up on designing the ideal 2-stroke exhaust port height to achieve expansion chamber scavenging from cylinder pressure and pipe restriction and resonant wave backpressure. My father watched me resolve the math wrong, and then correctly, before commenting to focus on the three things needed for combustion first (air/fuel, heat of compression, ignition). It took a while to recognize it is much easier to motivate movement of burnt exhaust gas at 200 PSI, than to motivate movement of a mixed air/fuel intake charge at 14.7 psi (or in my 2-stroke world the crankcase pressure). The intake valve closing point, or dynamic compression start point, drives the one element of the combustion requirements that cannot be easily changed once the engine is assembled. Get the dynamic compression correct and the rest follows (the rest being mixed flow fluid dynamics in the intake and the scavenging pressure wave dynamics in the exhaust, and all the stuff the Taylor text in a University IC Engines course barely covers).
Solving the mystery of the optimal internal combustion engine never ends...
I did it the other way around though. I visualize the rod connected to the crankshaft at 90°, then swinging back to main bearing centerline. Same thing, just a different way to get there.
And this is why piston velocity and acceleration is greatest in the top half, or first 90° of it's travel. (somewhere around 70-80°)
And that brings up several new subtopics for this discussion but I'll go there a little later.
When my son was in High School, I took them out and taught him how to use them. Surprisingly he thought it was pretty cool, but not nearly good enough for his engineering courses. Most folks don't realize that these things were used (at times) to put a Man on the Moon. We were even issued a round one we affectionately called the "Wiz Wheel" at flight school to calculate wind drift. Particularly useful for long overwater flights, well before GPS and many aircraft that weren't yet equipped with Inertial Navigation.
Still can't bring myself to part with them...
GUSTO
GUSTO
I was a junior in high school and I definitely remember the '63 roll out. I didn't like them. I preferred the '59 - '62. But, that's been the story for me for every newly released Corvette model. Eventually I warm up to them (except the C4
)Steve
Doug
think of the 'eons' in which 'things' were designed and built to "slide rule accuracy"....
Bill
GUSTO
I had one of those "Wiz Wheels" too when I was in the flight program at Embry-Riddle in Daytona in '69.
Verne
http://www.tech.plymouth.ac.uk/sme/desnotes/scrank.htm
http://www.epi-eng.com/piston_engine...ion_basics.htm
This is why i guessed on that.
Doug
In any right triangle, the length of the hypotenuse squared is equal to the length of side A squared and the length of side B squared.
At TDC we know that the distance from crank center-line to the wrist pin center-line is equal to ½ the stroke plus the length of the connecting rod (1.625" + 5.7") or 7.325" (where the piston starts from)
For the sake of this problem, we can ignore the distance from the top of the piston to the wrist pin center-line.
Now we will need to determine the new distance from the wrist pin center-line to the crank center-line when the crank throw is at 90°. We will call the distance A, and since we’re dealing with a right triangle that will make the length of the connecting rod C (or the hypotenuse). That will leave B as the distance from the crank center-line to the big end of the rod, or ½ the stroke. We need to solve for A and subtract that from the same distance at TDC to determine how far down the cylinder the piston has traveled.
Using the Pythagorean theorem, we need to solve for A or A = the √ (square root) of C² minus B²
C² = 32.490 and B² = 2.641 therefore C² minus B² = 32.490 – 2.641 or 29.849 the √ of which is 5.463 = A
Subtract A from the distance we calculated above at TDC (7.325) and you have the distance the piston has traveled down the cylinder at 90° or 1.862"
Man, all this math makes my head hurt... I need to go stare at Jackfit's picture above for a few minutes...
GUSTO
GUSTO
The solution for all triangle problems is also found in "Machiners Handbook". A wealth of information about everything to do with everything.
GUSTO
As for myself, I went through engineering school using both plastic and metal ones - the one I used the most was (I think) aluminum with porcelain like yellow finish. No way my Dad was gonna trust me with the family heirloom one at that point!
In civil engineering/surveying the demand for trig functions was huge. Remember those thick reference books of trig tables? That and the slide rule were key tools of the trade. We also used a Curta calculator - see pic below -remember those?
When I got out of school in 1971 we were still using those old tools and references. In 1972 HP came out with the HP-35 digital calculator with built in trig functions, and eliminated the need for those ponderous books of trig tables. Why it was darn near God's gift to engineering!
I was making $800.00 per month, and couldn't move fast enough to spend half my monthly salary on an HP-35 at only $395.00 each!
Those were the days - when technology actually made things simpler and easier!
I was making $800.00 per month, and couldn't most fast enough to spend half my monthly salary on an HP-35 at only $395.00 each!
Steve
