DeWitts Radiator
Old Feb 6, 2017 | 03:45 PM
JL66REDCPE's Avatar
JL66REDCPE
C2 of Year Finalist (stock) 2019
Default DeWitts Radiator
Just ordered a new DeWitts radiator for my 66 BB. Ordered 1239066M. I am hoping this solves my temp problems sitting in traffic. The sale is pretty good as it brought the price down a lot.
Old Feb 6, 2017 | 05:11 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Not only the radiator, but carb jetting and vacuum advance can play a part in your issue. What are your timing numbers, and is the vacuum working properly? Dennis
Old Feb 6, 2017 | 05:24 PM
alexandervdr's Avatar
alexandervdr
when I jetted my carb 2 steps richer, temperature indeed went down
Old Feb 6, 2017 | 05:59 PM
JL66REDCPE's Avatar
JL66REDCPE
Thanks for the response.
Car is not running lean and the timing is set correctly, not by the shop manual however correct, I think it is running 14 degrees advance at idle with vac hose disconnected and plugged.. The vacuum can is working properly. It is a VC1810 and I tested it with a vacuum gage. It is running with ported vacuum. Also fan clutch seems to be working ok as well - not a K&B but from Paragon. I use 100% avgas.
Old Feb 6, 2017 | 06:00 PM
JL66REDCPE's Avatar
JL66REDCPE
Yep a lean carb will make it overheat. Holley 3247 carbs tend to run lean anyway.
Old Feb 6, 2017 | 08:17 PM
leif.anderson93's Avatar
leif.anderson93
If this is the one you bought, it is a K&B product
https://www.paragoncorvette.com/p-36...utch-unit.aspx
Old Feb 7, 2017 | 06:43 AM
JL66REDCPE's Avatar
JL66REDCPE
[QUOTE=leif.anderson93;1594038045]If this is the one you bought, it is a K&B product
Thanks -- I will have to check. I bought it quite a while ago
Old Feb 7, 2017 | 09:04 AM
SWCDuke's Avatar
SWCDuke
Assuming it's a '66 L-72 that's why it's running hot in low speed traffic. Converting from the OE ported vacuum advance to full time will likely solve the problem. You can do a test by buying a couple of feet of 1/8" vacuum hose and a tee. Remove the existing choke vacuum break hose and make a new harness with one port routed to the VAC. Go through the idle speed mixture adjustment procedure after you make the change. Assuming it's a OE L-72 cam, shoot for about 900 idle speed, which should yield about 14" manifold vacuum.
You can also modify the carb base by plugging one hole and drilling another to move the VAC signal port above below the throttle valve, which makes the mod invisible.
There's a good chance you don't need a new radiator.
Duke
Old Feb 7, 2017 | 02:53 PM
watson's Avatar
watson
The Dewitt radiator is a quality product and that might solve your problem. If not, try adding the restricted bypass fitting to your water pump. It makes the water stay in the radiator a little longer and the engine runs cooler. My 67 L68 would get a little hot in stop and go driving on hot days. I tack welded a washer inside my hose fitting and I was amazed at the difference. The restricted fittings claim to lower water temp by 10 degrees and I believe it.
Doc
Old Feb 7, 2017 | 02:59 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Duke
a NEW radiator and/or extra cooling capacity is NEVER a waste.
Bill
Old Feb 8, 2017 | 08:17 AM
JL66REDCPE's Avatar
JL66REDCPE
Duke
Duke - I doubt if you will remember this -- I tried this exact modification and believe it or not, the car ran hotter !!!! I know this is hard to believe and I could not believe it either. I attributed it to the modification leaning out the engine. The radiator was re-cored about 25 years ago however it only has 5500 miles on it.
Old Feb 8, 2017 | 10:32 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
I have also had 'problems' with some of Duke's 'advice'....
Bill
To DeWitts Radiator
