65 speedometer
Old Mar 12, 2017 | 05:50 PM
65 396's Avatar
65 396
Default 65 speedometer
I need some help getting my speedometer setup correctly. When I'm driving 50 mph, I'm actually going 63 mph. How many less teeth do I need to make the speedometer read correctly?
Old Mar 12, 2017 | 06:31 PM
irwiny's Avatar
irwiny
http://www.stl-vettes.com/65vette/gearcalc.htm
Should help you get the correct gear if you have a M21 4 speed.
Irwin
Old Mar 12, 2017 | 09:12 PM
hope2's Avatar
hope2
12 - 13% less
Old Mar 13, 2017 | 08:58 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
50/63 = 0.793
IF you pull the driven gear in your trans, and find that you have 22 teeth, for example...
22 X 0.793 = 17.4 round down to 17.
In this example, you'd need a 17 tooth gear....
http://www.thegearbox.org/catalog/it...82/3697857.htm
HOWEVER, note the 2 different sizes of DRIVE gears in the transmission and note the DRIVEN gears that are used with that particular sized drive gear.
Remember too that the diameter of your tires as well as changes in the rear gear ratio might be causing the large discrepancies in your speedo reading...... assuming that the speedo head itself is properly calibrated.
To 65 speedometer
