Matching #'s
Old Mar 16, 2017 | 06:41 PM
Boyan's Avatar
Boyan
Default Pad
Original engine that was slightly decked. Dont let anyone do that again! There is another after the R, you just have to find it.
Old Mar 16, 2017 | 06:55 PM
rtruman's Avatar
rtruman
Originally Posted by Railroadman
If the transmission was replaced with another one, then it's not a "numbers matching" car.
Is there a definition stating that your idea of trans not original defines that where can I find that.
Old Mar 16, 2017 | 07:27 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Not sure what you are asking. But if I translate right you're asking what the term means.
There is no book that I know of that gives an "official" ruling. But the whole idea is self-explanatory. Some parts, on some years, are coded with a derivative of the VIN, thus proving that they are the original part that came with the car. A car with all the "born with" parts is worth more to some people than a car with parts which have been replaced.
You may see cars advertised as "NOM" - meaning Not Original Motor. That car would not be considered "numbers matching". Likewise the OP's car is a "NOT" to invent a term - "Not Original Transmission". Since the tranny number would NOT match the VIN, the car would not be properly considered Numbers Matching. I suppose we need a new category - "SNMOD" - Some Numbers Match, Others Don't.
Hope this help explain it. Personally I think the whole concept has gotten way out of hand with people spending cubic dollars on cars claiming to be matching, with people going to great lengths to fake number stamps, and with people advertising 1957's or whatever year as "numbers matching" when back then they didn't even put VIN number derivatives on the components.
Old Mar 16, 2017 | 07:30 PM
Rumblegutz's Avatar
Rumblegutz
As phil2302 says the circular machine marks on the pad surface are typical of a block that has been decked some time after original manufacture.
Although making a definitive conclusion from a photo is hazardous at best your stamp does is encouraging. I would suggest you clean the pad as best you can. DO NOT USE ANYTHING ABRASIVE. You do not want to create any abrasive marks at all. Start with some lacquer thinner on a rag. If stains from corrosion remain apply some Naval Jelly. Let it sit from as long as you can. Then wipe clean. When you have a clean, clear as possible as you can get pad surface take another picture. Try to get the camera as square to the pad as you can get. Post the photo.
Following a satisfactory photo shoot apply a film of oil to the pad surface to protect the pad surface.
If you are lucky maybe a second second suffix character will be perceptible.
Good Luck.
Old Mar 16, 2017 | 07:42 PM
Rumblegutz's Avatar
Rumblegutz
Although your sentence is a little awkward to parse I think I get the jist.
I believe what Railroadman has said is simply common sense and accepted by convention.
"Matching numbers" is not not limited by the tunnel vision view that those numbers are limited to that set found on the engine block stamp pad.
Old Mar 16, 2017 | 07:43 PM
rtruman's Avatar
rtruman
That's why I asked I knew it wasn't easy question who's to say he doesn't have the Vin stamped on Trans
Old Mar 16, 2017 | 07:50 PM
Rumblegutz's Avatar
Rumblegutz
Again your run on sentence or statement is a bit of a challenge to get a clear understanding of. May I suggest, punctuation is our friend.
To answer your question, it appears that the original poster says it is not when he states he is aware the trans has been REPLACED.
Old Mar 16, 2017 | 07:56 PM
Railroadman
Well, this leads right to the whole point of the discussion we often have. It USED to mean - by unwritten agreement - that the various components were original to the car, as confirmed by the numbers.
In more and more cases, it now means only that someone has stamped a number on the components, which matches the VIN. The object, to some, is that the numbers themself are the same, with no regard (or with deliberate disregard) for whether the component is indeed the one car car was made with.
Let me add that from what I can see, the OP in this post is very open and forthcoming that the trans is not original to the car, and I am not in any way saying he trying to be dishonest or misleading. I am talking about all the other cars we see out there with varying degrees of credibility for their claims of "numbers matching".
Old Mar 16, 2017 | 08:03 PM
rtruman's Avatar
rtruman
I thought and it sounded to me you were hard on that guy .
Old Mar 16, 2017 | 08:26 PM
Ems64's Avatar
Ems64
Boy, opened a can of worms there, didn't I? My apologies. While I state that the transmission was replaced at one time...that, in fact is "family lore" passed down from the two uncles that owned the car. I could question the one Uncle who is still, fortunately, with us. But I would guess his memory is foggy, at best....but I will definitely inquire the next time I see him. However I do agree with Railroadman, and always have been under the opinion, that the car is a "non #'s matching" car, for that reason.......and is not "original". Not a concern at all too me as the car is more of a family heirloom and something that I am incredibly proud of, due to the care my father gave it and all the hard work we have put into it over the years. I will never, ever sell it and will simply pass it down one day, as my father did, for the rest of the family to enjoy. My only intention was to verify something that I had wondered about for many years, and that was whether the engine block was original. And it seems, that in a matter of hours, we have managed to atleast mostly confirm that.....and I thank you guys for all of your assistance. That's what this forum is about after all....right?
Old Mar 16, 2017 | 08:29 PM
Railroadman
I was questioning his choice of words and use of the term. I was NOT questioning his integrity.
Old Mar 16, 2017 | 08:32 PM
Railroadman
I agree 100%. I am glad you took my remarks as intended - no offense or suspicion was meant and I'm sorry if I did not make that clear.
Old Mar 16, 2017 | 08:38 PM
  #33
rtruman's Avatar
rtruman
Old Mar 16, 2017 | 09:12 PM
  #34
Ems64's Avatar
Ems64
Now that's what I'm talking about.....
Thank you, Gentlemen....I will continue to "lurk" quietly and not cause anymore problems. I WILL try and get a clear shot of that block stamp and post when I have a chance. Thank you again.
