ok so who sells a complete heavy duty rear end assembly for a C2. I will have a 650 horse 427 small block, a Tremec 600 trans and want a bullet proof rear end. Looking for the whole setup except brakes
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
If you put slicks on the car, with that kind of power, in addition to the rear end, better make sure that you have HD half shafts and rear spindles, or you will just transfer the breakage to another part.
Look into the 30 and 31 spline parts. I used his entire package 1/2 shafts outer spindles and rear end parts. very nice pieces. Not cheap but worth it if your car makes power.
