66 Flasher
Old Mar 29, 2017 | 09:49 AM
Tcheairs38655's Avatar
Tcheairs38655
Default 66 Flasher
Where is the turn signal flasher located on a 66 and what is the best way to test it's operation...Thanks
Old Mar 29, 2017 | 10:16 AM
NightshiftHD's Avatar
NightshiftHD
Its on a big clip mounted on the drivers side radio panel.
Old Mar 29, 2017 | 11:01 AM
65GGvert's Avatar
65GGvert
Yes, right above the antenna switch. And if I wanted to test it, I'd go to Autozone (or equivalent) and buy one for $7 and change it out. You could measure for 12v on the brown wire with the key on, but that brown also feeds the wipers and heater fan, so if only the turn signals don't work the fuse is ok.
http://www.autozone.com/electrical-a...3_132997_11714
To 66 Flasher
