Idle question
Old Mar 31, 2017 | 04:41 PM
phil2302's Avatar
phil2302
Originally Posted by Twan Sloot
Well I only have the car 7 months or so and because of our really wet winters this was my first longer drive than 10 minutes, and I first noticed the problem after leaving the highway the engine was nice and hot and it would idle real low it even idled for 350 for a second or 10 after that it died and would fire right up and as soon as throttle is applied it drives like you would expect it to do. The next day nothing wrong start up the car idles at 1500 until I drive it for 5 minutes (choke cuts out because engine is warm) and the car idles at 450 again and eventually it can't stay on with the extreme low idle and dies, again fires right up.
Edit: forgot to mention the fuel is 7 months old, filled it up when it arrived with 98.
7 month old fuel shold be fine.
If low idle is the only problem and it is running strong through the gears I am betting you just need to set the curb idle.
Old Mar 31, 2017 | 07:05 PM
Twan Sloot's Avatar
Twan Sloot
I hope that's the case the only thing it does besides low idling is humping(as if you try to drive off in a car with to little throttle and to fast clutch release) when you try to drive a constant rpm, like 2000 or so in first or second gear, driving on the highway on a constant rpm is no problem
Old Mar 31, 2017 | 08:30 PM
phil2302's Avatar
phil2302
If by saying "humping" you mean it is stumbling when starting off in 1st gear that may indicate more than just a curb idle issue.
Old Apr 1, 2017 | 05:54 AM
tbarb's Avatar
tbarb
Does this 300hp engine have it's stock camshaft.. You are saying the engine has a surge at the 2000rpm range, Correct? Make sure there are no vacuum leaks and check the vacuum advance control to make sure it holds vacuum. You have got to start with all the simple things and eliminate them before going to the carburetor .
Old Apr 1, 2017 | 05:57 AM
Twan Sloot's Avatar
Twan Sloot
No that's not what I mean, hard to describe for me in english, I mean that when I try to drive a constant RPM so 2000 or 1800 it feels like it stumbles, it's very little not enough for the tach to show any bounces, but you can feel it in the car. This only occurs when I drive a constant RPM any form of accelaration and it's fine again. So pulling off with the car is no problem and again all the problems are gone when the choke is still engaged. But I will work on the car today, and see where I can get with all your great advises already.
Old Apr 1, 2017 | 06:03 AM
Twan Sloot's Avatar
Twan Sloot
Nope not a surge just a slight stumble when I drive a CONSTANT speed at any rpm. You can accelarate the car through all the rpm's and all the gears with no problem at all. But it idles too low and driving a constant speed it stumbles so slightly.
But again all solved when coke is engaged.
Ps have to add that it won't stumble if you drive a constant speed at a highr RPM so highway driving isn't a problem
Old Apr 1, 2017 | 06:10 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
the choke engaged richens the mixture and driving at higher speeds increases the load on the engine thereby richening the mixture.
sounds like a lean surge
why do I think that? because that is the way I adjust my fuel injection; I lean it out until it surges and then richen it till it just goes away
Bill
Old Apr 1, 2017 | 06:14 AM
tbarb's Avatar
tbarb
Go through the idle speed and emulsion screw adjustment when the engine is hot to see if you can correct the idle issue. Your other stumble problem sounds like the accelerator pump needs to be adjusted, there is also a check ball above the accelerator pump that can cause a delay in pump shot if not adjusted right but you need to remove the pump cover to check. spend some time and do Internet on the adjustment.
Old Apr 1, 2017 | 06:57 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
The accelerator pump is not the cruise problem...there may be two problems...
His cruise prob is a lean surge or the timing is over-advanced (e.g. too much vacuum advance). Those are the two issues that cause cruise speed "trailer-hitching"
Old Apr 1, 2017 | 07:52 AM
Twan Sloot's Avatar
Twan Sloot
Well I was planning to drive it until it's warm and then work on the carb, but the weather has turned around rain showers all day
Old Apr 1, 2017 | 11:58 PM
Goldduster's Avatar
Goldduster
I have a similar problem. When I returned to the carb rebuilder they found a problem in the choke thermostat. They are fixing it under their warranty
Old Apr 2, 2017 | 08:10 AM
Twan Sloot's Avatar
Twan Sloot
okay so I think there is more going on now. I am going to start this from the day I bought the car that's best I think.
we bought the car when winter was upcoming and we drove it for 15 to 20 minutes with 41 degrees Fahrenheit outside temp. the car drove great, no sounds not one thing wrong. then we stored it for winter. it was fired up twice during winter to let some friends hear the sound no probs. probably 3 weeks ago I drove it for the first time again, the outside temp was now 63 degrees. the car ran great but after 5 minutes of driving I heard a bang from the engine, but with the side pipes it wasn't really sounding loud and I didn't think to much of it since the car didn't had any issues until then. after that ride I drove it in the garage and have no idea if the car idled low already, at least didn't took notice of it.
a few days ago the first 30 minute drive was up and after coming down the highway it idled at 400, and all the problems that you read earlier in this thread appeared.
today I was planning to work on the carb, so I drove the car and opened the hood to adjust the curb idle screw, while doing that I asked if my brother could give the engine some gas and releasing the throttle again. and now I heard the bang from the enige I heard earlier but now heard it with the hood openend and I am for sure something is wrong. allthough the engine keeps running fine that bang scared me.
what could this bang from the engine be?
PS I have to add that the first time the bang appeared while shifting, now it appeard with clutch fully pressed and gear in neutral.
Old Apr 2, 2017 | 08:38 AM
  #33
Frankie the Fink
Army
Raw gas igniting in exhaust manifold. Lean mixture or loose exhaust manifold bolts. All of your symptoms are pointing to timing or mixture issues. Or possibly a vacuum leak causing leanness.
Old Apr 2, 2017 | 09:04 AM
  #34
MikeM's Avatar
MikeM
Pull the spark plugs and see if any are fouled.
Old Apr 2, 2017 | 10:43 AM
  #35
Twan Sloot's Avatar
Twan Sloot
But aren't you now suggesting it's a backfire, because this wasn't a backfire at least it didn't sound like one it really came from te engine.
Old Apr 2, 2017 | 10:57 AM
  #36
Frankie the Fink
Army
Its subjective.
I don't know of anything else that would cause a 'bang' in the engine compartment that wouldn't be a serious issue...
An exhaust backfire (out the tailpipe) is a bit different from one occurring in the exhaust manifold. The former can blow a muffler out, the latter can cause more serious problems; e.g backfiring through the intake manifold and out the carb. I lost eyebrows, a mustache and all my nasal hair, got a nice sunburn and ruined some underwear once from a carb backfire...
I rarely, rarely run a car without the air cleaner on; I'm combustible. Maybe post a video ?
Old Apr 2, 2017 | 11:35 AM
  #37
Twan Sloot's Avatar
Twan Sloot
Its subjective.
Haha, I can post a video but I don't think you can hear much more than an engine idling to low, the banging sound only occurs very seldom
To Idle question
Old Apr 2, 2017 | 11:58 AM
  #38
wmf62's Avatar
wmf62
St. Jude Donor '07
terms are getting confused here...
from this link: http://www.6crew.com/forum/showthrea...-Misconception)
BACKFIRE:
A backfire is an explosion that's created by an engine that occurs in the air intake system rather than inside the combustion chamber where it is normally supposed to happen. Fuel and some unburned hydrocarbons are ignited somewhere in the intake prior to making it into the combustion chamber or somehow gets blown back past the intake valves. This condition causes a looud abrubt popping noise and will cause loss of power and forward motion and can and will damage the intake tract or possible other parts IE- turbo, sensors, and etc. A backfire is a separate phenomenon from an Afterfire.
WHAT CAUSES A BACKFIRE?
Backfires can occur when running too far of advanced timing, running cams with a massive overlap and having the car not tuned properly for the application as well as just having mechanical valve failure, IE- somehow the valve timing is thrown off or the valves arent seating properly and fuel is push back up past the intake valve during ignition. While there can be more things that cause a backfire, these are just a few.
AFTERFIRE:
An Afterfire, sometimes called Afterburn, is an audible popping sound, individual or multiple that often occurs when the fuel/air mixture is too rich or has a momentary instance of a rich condition. This pop at times can and do resemble small caliber firearms going off. Afterfire occur in the exhaust system post turbo or post engine typically.
WHAT CAUSES AN AFTERFIRE: Richer fuel mixtures are also slow burning. This results in the exhaust gases to have some amount unburned fuel passed on to it as it exits the engine. As it exits the engine, that unburned fuel and any air leftover from combustion mixes and ignites somewhere in the exhaust. Afterfire's are more common where long exhaust ducting retains greater amounts of unburned fuel due to rich fuel mixtures. Afterfiring can also be caused by cylinders which are not firing because of faulty spark plugs, defective fuel injector nozzles, or incorrect valve clearance
Of the two phenomenon's a true backfire is not something any car modder wants to happen. especially a nitrous backfire. An Afterfire is normal and ever vehicle does it to some extent. more pronounced when dealing with higher flowing and free flowing exhaust. but they are common and typically do not pose any immediate threat to the engine and surrounding parts.
Bill
Old Apr 2, 2017 | 12:08 PM
  #39
Twan Sloot's Avatar
Twan Sloot
BACKFIRE:
AFTERFIRE:
Bill
well that was pretty clarifying and yep I misused backfire
Old Apr 2, 2017 | 12:12 PM
  #40
wmf62's Avatar
wmf62
St. Jude Donor '07
and I still think you might be having a lean surge...
Bill
