[C2] Brake issue
Old Apr 2, 2017 | 05:17 PM
Dave Witman's Avatar
Dave Witman
Default Brake issue
67 vette with 427 BB oring stock calipers 7 inch dual diaphragm booster 1 1/8 inch bore master cylinder and remote vacuum pump for booster producing 20hg. Booster test out fine. Problem is takes a lot of pedal force to get good stopping power. Not bad at low speeds but high speeds will make you pucker. Only thing I have found is pressure diff. valve for light is showing about 6k ohm on meter no light is not on but I think it should be open circuit. Also would a 1 inch bore master cylinder help my issue. Dave
