My 67 327/350 coup sat for four years. Last summer I got back to it and found the brakes poor. I opened the master cylinder and found one of the two troughs empty (I think the rear but am not certain). I then rebuilt the brake cylinder, installed it, uninstalled it and then bled the MC before reinstalling it, put in new one way bleeders, rebuilt the calipers, new pads and new front hoses with new short rear lines to the calipers.
I have a Motive pressure bleeder. Today I checked with air pressure and found no leaks. I then put brake fluid in the Motive container and went to the right rear to bleed. Neither of the bleeders made any sound of rushing air nor did either end up with any fluid. I then checked the other three corners and all bled just fine, ending with no air bubbles and just solid brake fluid.
A visual inspection reveals no kinks or leaks of the rear solid lines to the caliper.
I can't figure out why there is no fluid going to just that one caliper. I'm at wit's end.
Any help would be greatly appreciated (Other than an inquiry as to type of fluid used- I just don't want to start that ball rolling again)
You may have a piece of rust or something blocking the line somewhere. It could be in the line or master cylinder but my guess is in the brake line somewhere. You may have to hook up an air line and try to force air thru the line. If you do please be careful not to blow break fluid on paint or anything. You may want to cover the open end with a cloth of some type. Good luck.
HELP
Replace the rubber line that will not bleed. They break down inside when sitting for a long time. I would replace both rubber lines.
There is no rubber line. I checked the caliper brake line and the fitting that connects to the long brake line has fluid. I then took the fitting off where it connects to the caliper and nothing came out. I assume there is some obstruction inside this line. Just to be safe, I ordered a new one. I will replace this line just to make sure.
Oh well, what is another week waiting for parts? I could blow it out but then I would always wonder if there are other bits of whatever inside the line waiting to cause havoc. A $15 replacement is peace of mind.
Thanks for the replies, they led me to check and find the culprit. You folks here are the best!
There is a rubber line before the steel line running directly to the brake caliper in the rear. If there wasn't the metal line would break when the rear suspension moves. It could be obstructed. I would replace it as they will go bad and seal up when the inner lining breaks down.
Dan, you are spot on. Thanks!!! I just added both side hoses to my order.
D & M Corvette in Downers Grove usually has these in stock, along with many other parts. Joe is the main contact in the parts room. The prices are comparable to catalog order prices.
I completely forgot about D&M. A lot better than ordering and waiting for parts.
BTW: Some folks claim the SS lines increase pedal firmness because the SS line doesn't expand as much as the rubber line...I used SS lines on my 67...I didn't know any difference...
Either way is fine...SS is a little more money...
The guy that restored my car used SS lines. To me it's an over kill and in my experience in using them they tend to leak at the flare joints because the metal is harder then regular steel and will not seal as well.
