Another Won't Start Thread
I have a 1967 427 3X2 400hp. I bought it one year ago. It had sit for 17 years.
I had the carburetors rebuilt and got it running. It would start fine until about 6 weeks ago. If I let it sit a few days it was hard to get it to start. When it did start it was rich but it would clear up and run fine after a few minutes. After starting I could drive it all day and it would start right up, first try.
It has new Petronic plug wires and AC, R45XLS plugs. Last week I got it to start so I took it to a buddy's house and we changed the distributor cap, rotor, points and condenser. We set the timing and dwell and I drove it home. It ran fine and started up several times. I let it sit a few days. This time before I tried to start it I removed the float bowl screws on all 3 carburetors and checked the float level, all bowls had fuel up to the bottom of the hole. I checked the accelerator pump and It was pumping a good stream of fuel. I tried to start it, it would spin over but no start. I opened the choke and tried again it would spin but not start.
I held the gas open and tried again, no start. It never acts like it's trying to start up.
I've pulled all the plugs several times and they look to be firing fine. Sometimes when I've pulled the plugs a few would be wet sometimes not. I've poured a little gas in the center carburetor, no help. I've always been told if you have Fire, Fuel and Air it will crank...not so far, for this car.
The coil is a possibility but what's happening with your choke? Is it set correctly for a cold start?
Next time it won't start, put a test light on the distributor side of the coil and crank the engine. You should see a bright light flashing off/on. Not dim/bright.
