[C2] Reverse lock out-M20
Old Apr 19, 2017 | 05:34 PM
Mizmaryann's Avatar
Mizmaryann
Default Reverse lock out-M20
Finally took my 65 in to inspect my trans linkage/reverse lock out. The linkage and lock out have been need of repair for some time. The prognosis was the linkage was worn, sloppy; so I got new linkage kit from Full Throttle Corvette. The new kit definitely improved the action, but the lock out is still inoperative. Question; is there a lock out kit available or is a new shifter necessary? Or would this be a good excuse for a 5spd from Siver Sport?
Old Apr 19, 2017 | 05:38 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the lock out rod is a very simple design. when you pull up on the "T" handle it pulls up a rod that has a pin that pulls out of the shiffter allowing it to go into reverse. either something inside your shiffter is broken or your out of adjustment on the linkage rod
Old Apr 19, 2017 | 06:20 PM
MikeM's Avatar
MikeM
This thread shows how the lockout works. You can spend maybe a few bucks to fix it or you can spend hundreds and hundreds on your new transmission.
https://www.corvetteforum.com/forums...t-problem.html
Send me your old transmission and linkage. I'll pay postage.
Old Apr 19, 2017 | 07:31 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
[QUOTE=MikeM;1594564928]This thread shows how the lockout works. You can spend maybe a few bucks to fix it or you can spend hundreds and hundreds on your new transmission.
You mean, thousands on your new trans! Dennis
Old Apr 19, 2017 | 07:43 PM
MikeM's Avatar
MikeM
[QUOTE=Bluestripe67;1594565439]
Sounds like we need a cost/benefit ratio analysis on this problem.
Old Apr 20, 2017 | 10:49 AM
Mizmaryann's Avatar
Mizmaryann
Thanks, MikeM; from your link we found the rod about 1/16" short. So we adjusted and now it works great! THANKS
To Reverse lock out-M20
