[C2] 67 mirror vibration
Old Apr 24, 2017 | 03:21 PM
Bluffman's Avatar
Bluffman
Default 67 mirror vibration
Does anybody else's rear view mirror vibrate, when I give it gas at highway speeds it starts vibrating, and I can't see anything but a blur. My side mirror is perfect. Ian
Old Apr 24, 2017 | 04:36 PM
Gary's '66's Avatar
Gary's '66
Ian,
The only time I have had this happen was when the car itself had a vibration. Either the mirror is loose or, you have some sort of issue with the car which, can be a PITA to diagnose.
Going by what little info you've posted, it sounds as though it MAY be drivetrain related.
Gary
Old Apr 25, 2017 | 12:50 PM
Bluffman's Avatar
Bluffman
Yeah I am going to check drivetrain for vibration
Old Apr 25, 2017 | 02:02 PM
Gary's '66's Avatar
Gary's '66
To start, there's lots of info in the archives as, this is a very common issue. Just type in "Vibration" in the "search this forum" box.
Other than the drive train, another area that comes into play would/could be the tires, ei balancing, flat spots, out of round, etc.
Good luck. You may want to report back on what you find or, don't find.
Gary
Old Apr 25, 2017 | 02:06 PM
kingwoodvette's Avatar
kingwoodvette
I have the exact same problem with my 63. Just returned from a 600 mi round trip. Windshield mirror vibrates at hi way speed but the side mirror is perfectly steady. Don't understand one vibrating and the other not.
Old Apr 25, 2017 | 05:39 PM
Gary's '66's Avatar
Gary's '66
Unless both mirrors are loose (as mentioned earlier) you and, the OP, MUST be feeling some sort of vibration elsewhere such as at the steering wheel, pedals, shifter (excluding 4th gear buzz) floor panels, etc.
The side mirror, unless loose, usually won't vibrate. The only time I have had my inside rear view mirror vibrate to the point that I couldn't see was due to (in my case) several different drive train issues.
Gary
Old Apr 25, 2017 | 05:47 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
One bolts to the birdcage; the other one doesn't
Old Apr 25, 2017 | 05:50 PM
Gary's '66's Avatar
Gary's '66
Thank-you!
Gary
Old Apr 25, 2017 | 09:45 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
1967 also, count me in on the rearview mirror vibration. The rest of the car seems so smooth.
Old Apr 25, 2017 | 11:19 PM
Bluffman's Avatar
Bluffman
So bolting to the birdcage means, tires or drive shaft. Ian
Old Apr 26, 2017 | 07:38 AM
kingwoodvette
Thanks guys. The outside mirror being bolted to the door does provides some isolation from the frame/ drivetrain. Car drove amazingly smooth on this recent long highway trip. I'll start with tire rotation and balance.
Old Apr 26, 2017 | 02:05 PM
Gary's '66's Avatar
Gary's '66
Or............. snubber bushing, U joints, axle bearings, dampener, etc., etc., etc.!
As mentioned, vibrations can be a PITA to diagnose.
That's why I referenced using the "search this forum" app and type in "vibration".
Gary
Old Apr 26, 2017 | 02:53 PM
leif.anderson93's Avatar
leif.anderson93
How long have you owned the car?? Has the interior rearview mirror always vibrated?? Do you have one of these installed??
http://www.parts123.com/parts123/yb....Z5Z5Z50000370a
Old Apr 26, 2017 | 05:52 PM
Gary's '66's Avatar
Gary's '66
Good point Leif. Cheap too!
Gary
Old Apr 26, 2017 | 10:48 PM
kingwoodvette
Gary
I agree. I'm not near mine-at Disney World with 2 daughters and granddaughters. Will check when I get home. Thanks for the idea.
Old Apr 27, 2017 | 09:25 AM
Bluffman's Avatar
Bluffman
I will check and see if I have that bushing. Thanks that would be cheap and a clean hands fix. Ian
Old Apr 27, 2017 | 09:56 AM
Jackfit's Avatar
Jackfit
JohnZ stated that without that part, your mirror will always move......
Jack
To 67 mirror vibration
