[C1] 1958 trunk question
Old May 5, 2017 | 10:40 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Default 1958 trunk question
There are openings on both sides in the floor of my trunk that I can see the shackles. Should they be there and if so are there plates to cover them.
Old May 5, 2017 | 11:56 AM
rfn026's Avatar
rfn026
There should be plates there. They're called access panels. There are a number of them. The originals are metal.
Richard Newton
Useless Tech Stuff
Old May 5, 2017 | 12:00 PM
wilbur's Avatar
wilbur
Yes there should be access covers.
​​​​​​​ I believe early 58 used metal and sometime throughout the year they changed to fiberglass
Old May 5, 2017 | 07:57 PM
thoyer's Avatar
thoyer
Old May 6, 2017 | 06:25 AM
papaed's Avatar
papaed
1st Gear
Mine are fiberglass. odd shapes. I can send copy of pattern if i knew how!
Old May 6, 2017 | 06:48 AM
327carguy's Avatar
327carguy
Mine are also fiberglass. Basically flat sheets (press-molded) cut to fit the inside profile of the rear fenders. The are held in place with oval head Philip screws. My car is from early January 1958. Hope that helps
Old May 6, 2017 | 08:40 PM
thoyer's Avatar
thoyer
A couple pics from a VERY original 58 being judged at the Florida
Regional a couple years back. March 58 car.
Tom
Old May 7, 2017 | 04:36 PM
hawkfe's Avatar
hawkfe
2017 C1 of the Year Finalist
Was 58 the last year they used them, having problems finding part numbers for a 59
Old May 7, 2017 | 05:41 PM
Pilot Dan's Avatar
Pilot Dan
Yes, 59-60 did not use them. I think in the later part of 58 production they were eliminated.
To 1958 trunk question
