Engine Part Question
Old May 10, 2017 | 06:35 PM
Burnt71's Avatar
Burnt71
Default Engine Part Question
Putting a Tarantula intake on a 1964 283. What is this part I'm pointing to and do I neeed it ? it keeps my intake from fitting ?
Old May 10, 2017 | 06:50 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
That's the oil vapor cannister. It's part of the PCV system.
Can it be removed? Yes.
Are you going to need to do something else to vent the crankcase? Yes.
Old May 10, 2017 | 06:53 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Leave it and get a draft tube or PCV.
http://www.parts123.com/corvettecent...50e&ukey=32735
Old May 10, 2017 | 06:55 PM
BacknBlack08's Avatar
BacknBlack08
It's a breather system for the engine. Long before the invention of the PVC system they used these in the early years to allow the engine to breathe. I have seen people remove this and cap off the hole behind the distributor with a correct size freeze plug. That hole originally had a pipe that was directed down toward the bottom of the engine that put the expelled air under the car. You would have to come up with a PVC or breather system in the valve covers to totally eliminate the canister you are pointing at. Take some time to read up on SBC PVC systems to see what would work best for your conversion.
Hope this helps
BNB08
Old May 10, 2017 | 06:57 PM
BacknBlack08
According to him he cant leave it, his intake wont fit
Old May 10, 2017 | 07:28 PM
SWCDuke's Avatar
SWCDuke
That device is a liquid/vapor separator (regardless of what anyone else called it), and all SBs through '67 have one. If not the engine is going to be puking a lot of oil out on the road via a road draft tube or into the inlet manifold if it has a PCV system.
I'm just curious, but why are you installing a big port, single plane manifold, essentially a racing manifold designed for big port heads on an engine cammed for maximum power from 5000-up on a small port head 283?
Duke
Old May 10, 2017 | 07:32 PM
Burnt71's Avatar
Burnt71
Originally Posted by SWCDuke
That device is a liquid/vapor separator, and all SBs through '67 have one. If not the engine is going to be puking a lot of oil out on the road via a road draft tube or into the inlet manifold if it has a PCV system.
I'm just curious, but why are you installing a big port, single plane manifold, essentially a racing manifold designed for big port heads and cammed for maximum power from 5000-up on a small port head 283?
Duke
I was told this was a good manifold for high revving engines like the 283s
Old May 10, 2017 | 08:01 PM
Burnt71's Avatar
Burnt71
OK I might have solved my own problem , I found an old cast Iron manifold in the barn ( 3844459 ) I think from a 327 fits right on and it has the breather cap on it also. My goal was to get rid of the 2 barrel It was damaged during storage Now I can use a quadrajet
Old May 10, 2017 | 09:33 PM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
I don't think you can use a quad with that manifold. Maybe an AFB?
Old May 11, 2017 | 05:51 AM
Chuck Gongloff
http://www.ebay.com/itm/281727564084?rmvSB=true
Old May 11, 2017 | 07:16 AM
Burnt71's Avatar
Burnt71
Darn it your right . it;s a square bore
Old May 11, 2017 | 07:17 AM
Burnt71's Avatar
Burnt71
Ok I have an old Edelbrok 1407 Performer Square bore carb I can use.
Old May 11, 2017 | 07:26 AM
Burnt71's Avatar
Burnt71
Originally Posted by Chuck Gongloff
I paid $20 for mine at Carlisle a few years back. Thought I would never use it
Old May 11, 2017 | 07:48 AM
GUSTO14's Avatar
GUSTO14
I'm not sure where you're having an issue, I've had a Tarantula on this 327 since 1971 when Edelbrock first released the manifold.
Before restoration...
after restoration...
Good luck... GUSTO
To Engine Part Question
