[C2] Recommended Heater Core- '66 No A/C
I had my '66 convertible out last weekend and when I got home I noticed a few drops of antifreeze on the passenger side floor mat. BTW, I was using the heater earlier in the day. My guess is a leak of some sort in the heater core. The car has a 327/300 engine, no A/C.
I've done due diligence looking in the Forum archives and I think I'm all set on what I need to do to replace it. From what I read, most new replacement cores don't quite fit correctly. Since I doubt it's the original heater core in the car I'm looking for suggestions on where to buy a replacement core that will fit correctly. I've had good experience with Paragon, Long Island Corvette and Keen Corvette Parts. Any thoughts or suggestions would be appreciated.
Thanks everyone.
Thomas
Thanks everyone.
Thomas
I've used the heater cores from Paragon several times, last time about 6 months ago for my '66. I've never had a problem/leak/fitment issue with the cores from Paragon. I do not know where all the vendors source their heater cores from, all I can say is I have had good luck with Paragon.
Received 6,943 Likes
2015 C2 of Year Finalist
If you have a old time radiator shop close by have your original re-cored
That gets me started so thank you gentleman for your recommendations. It is always much appreciated.
Thomas
The resto part house most likely sell the same ones sold by your local auto parts store. There you won't pay shipping and corvette tax
The last heater core I put in my '66 AC/Coupe was from NAPA. Fitment was correct. That was 12 years ago. This is a job you only want to do once. Pressure check your replacement first before you put it in regardless of where you get it from.
Thanks everyone.
Thomas
Thanks everyone.
Thomas
I just did the 66 so if you need any step by step advice, cautions etc, drop me a Pm
Thanks everyone for the additional information. I'll post my progress.
About 4 years ago...
...I replaced the radio speaker, and had the radio freshen up. Since the car was apart I thought long and hard about pulling the heater core and taking a look at it right then. At the time though I decided, if it's not broken why fix it?
So I've been pretty deep into the car and know it's a bit of a project but I've got a nice, comfortable shop to work in and I'm retired so I'll put some vintage tunes on the shop sound system and have at it. This time I'm going to remove the passenger seat to give me a little more working room.
keeks2915, I might take you up on your offer so perhaps watch for a PM from me!
Thomas
Thomas
Another tip, if you are replacing your carpet while doing this heater core, I found the BEST quickest way to get a pristine floor with all the glue residue gone. I use a dremel jam saw with the scraping blade and that crap peels up like you are peeling a potato. Zero elbow grease and no floor damage.
